F20C in an Integra
Old Feb 23, 2003 | 12:19 PM
JeremyL's Avatar
Default F20C in an Integra
i posted this in the hybrid forum but theyre pretty slow over there
anyway i was wondering if it was "reasonably" possible to drop a full motor, tranny, ecu, axles etc...swap into a 94+ Integra and make it RWD? how much of the Integra's chassis do you think would need to be modified?
Does the S2K have a front or rear mounted transmission?
Old Feb 23, 2003 | 12:37 PM
HKJ's Avatar
HKJ
Default Re: F20C in an Integra (JeremyL)
anything is possible with $$$
[Modified by HKJ, 9:38 PM 2/23/2003]
Old Feb 23, 2003 | 12:55 PM
JeremyL's Avatar
Default Re: F20C in an Integra (HKJ)
ill try searching but i mean why is it such an unreasonable thing to consider?
Old Feb 23, 2003 | 01:00 PM
JMX's Avatar
JMX
s2k is rear wheel drive, integra is front, there is your major problem
it would cost BIG BUCKS to do something like that.
Old Feb 23, 2003 | 01:02 PM
00VTEC's Avatar
what he said
Old Feb 23, 2003 | 01:05 PM
Audio28's Avatar
Default Re: F20C in an Integra (00VTEC)
are you looking to actually do this, or were you just wondering?
Old Feb 23, 2003 | 01:09 PM
JeremyL's Avatar
Default Re: F20C in an Integra (Audio28)
if it were reasonable as in under $10K i would very strongly consider it, i figure i will probably spend close to that to fully do my turbo project so why not have a rwd (much faster 1/4) stock motor car
and i know the drivetrain differences between the 2 and which was why i proposed the ? of how hard it would be to make the Integra RWD
Old Feb 23, 2003 | 03:33 PM
KoRE's Avatar
i would think it would cost well over $10k...
Old Feb 23, 2003 | 03:57 PM
JBBNJ609's Avatar
Default Re: F20C in an Integra (KoRE)
ive seen a lotise elise ( spelling) with a type r motor in it , and it ran like a 13.2 , cause its even ligther then a typeR , that would be cheaper just to do that . . .. . .
Old Feb 23, 2003 | 05:05 PM
JeremyL's Avatar
Default Re: F20C in an Integra (jason bouchard)
yeah just buy a $70k elise lol
Old Feb 23, 2003 | 05:16 PM
UberTeg's Avatar
Its possible. Your first problem is mounting the engine in the engine bay, which could be done by any competant welder. Second problem is knocking a hole under your firewall for the transmission. Third problem is where to mount the transaxle and differential, and how to get it past the gas tank. U could hack up your gas tank, and finding a mounting point for the transaxle and differential shouldnt be too hard. Fourth problem, you need custom axles (could be made, but will rpobably cost $$$). Fifth, and most major, problem, how to get the the axle into the hub! Your stock rear hubs dont have splines for an axle. And the rear/front hubs are totally different so u cant just bolt on the front hub to the rear. The only good solution to this, is to fabricate a new entire rear suspention (hub, knuckle, contron arms), and make it so the frotn hub will bolt on to it.
Now lets assume you did all of that, you would have to make the axle insert int othe hub at an angle, because u can pass the axle over the lower control arms mounting point like in the front. I wouldnt want my axles entering at an angle like that
Old Feb 23, 2003 | 09:17 PM
[TRB]RHD-DC2-TypeS's Avatar
i would guess the easiest way is to tube chassis the car, otherwise ur gonna have MASSIVE clearance problems with every single component relating to the drivetrain
Old Feb 23, 2003 | 09:35 PM
UberTeg's Avatar
Default Re: F20C in an Integra ([TRB]RHD-DC2-TypeS)
That would be t he easy way out
Old Feb 24, 2003 | 03:59 PM
JeremyL's Avatar
Default Re: F20C in an Integra (UberTeg)
maybe you could custom fit a 924/944/968 rear end with the rear mounted transmission and axles
Extreez
Aug 23, 2006 09:01 PM
STUCKED
Mar 1, 2006 03:43 PM
Kid1320
Jan 2, 2006 12:04 PM
Xtentual
Mar 26, 2004 01:53 PM
jdmintegra1994
Oct 9, 2003 01:04 PM
