vtec not working
Old Feb 19, 2003 | 03:35 PM
mulin's Avatar
Default vtec not working
i have a b18c motor and all the wires are hook up except for knock.
my vtec not working. could that be the problem. i also got the wire wet because my radiator hose busted. the vtec pressure and solenoid plugs got wet also. could that be a problem.
any sugesstions will be helpful
Old Feb 19, 2003 | 03:50 PM
Brett's Avatar
Default Re: vtec not working (mulin)
Hook up a wire tester (or a simple bulb) to the green and yellow wire between the ecu and the vtec solenoid and see if you're getting juice.
Old Feb 19, 2003 | 04:08 PM
x James Bond x's Avatar
Default Re: vtec not working (Brett)
Its been a while for me but
If I recall correctly with the knock sensor wire not hooked up you are going to be in limp mode and have NO VTEC, So HOOK that wire up.
05 S2K Stoner
Oct 28, 2004 06:40 AM
juicy.koreans.suck
Dec 25, 2001 01:54 PM
5 Liter Eater
Jul 16, 2001 09:57 AM
