Bottom End Help
Old Feb 21, 2003 | 09:02 PM
slammed93integra's Avatar
Default Bottom End Help
ok 93 ls bottom end re-building for all motor N/A
.20 bored over
eagle forged esp rods
eagle pistons 10.5:1 compression street/strip
if i bore the engine.....do i still need to hone/sleeve it??
if you have suggestions please leave them cause i want to get the best set up i can
Old Feb 22, 2003 | 07:58 AM
Default Re: Bottom End Help (slammed93integra)
ttt
Old Feb 22, 2003 | 08:03 AM
ragejed's Avatar
I belive you need to hone it to get the cros hatch lines in there (whatever they are called.) as for sleeving..No..since you are boring. As long as stock one is fine.
Old Feb 22, 2003 | 10:37 PM
Default Re: Bottom End Help (ragejed)
you know anything bout crower cams?
Old Feb 23, 2003 | 08:11 AM
VTECPWR's Avatar
You absoultley need to hone it. S;eeving is not necessary. Although if you are already in there I would consider getting sleeves and running a much larger bore 83mm - 84mm. This would give you close to 2 liters.
Old Feb 23, 2003 | 09:37 PM
Default Re: Bottom End Help (VTECPWR)
ok....if i am goin with like srp pistons 81.25 mm 10.5:1 compression with eagle rods and then boring the motor like .20 and then honing it will i be ok?? will i be done with the bottom end besides the piston rings?
GSRswapEk
May 25, 2016 07:42 AM
rags00prelude22
Nov 12, 2008 04:21 PM
Citystar
Jun 23, 2004 06:20 PM
Crate
Dec 5, 2003 03:34 PM
integra-modder
Jul 17, 2002 10:19 PM
