Bore Size
Old May 7, 2011 | 10:37 PM
turbo94teg's Avatar
Default Bore Size
Just wondering if anyone out there knows what the bore size would be on a B18b1 if you took it .50 over with new sleeves? Also what head gasket would you recomend on a turbo setup??
Old May 8, 2011 | 12:19 AM
mouab18c1's Avatar
Default Re: Bore Size
81.5mm; OEM ls headgasket
Old May 8, 2011 | 09:59 AM
da_all_day's Avatar
or a cometic headgasket... both are good...
Old May 9, 2011 | 01:53 PM
turbo94teg's Avatar
So a oem ls vtec head gasket will hold up with boost? I've been told cosmetics are good just over priced.
Old May 9, 2011 | 02:05 PM
mouab18c1's Avatar
OEM can handle almost anything.
Old May 9, 2011 | 07:41 PM
turbo94teg's Avatar
For real ?
Old May 10, 2011 | 09:52 PM
mouab18c1's Avatar
Search
Old May 11, 2011 | 11:14 AM
turbo94teg's Avatar
Thanks, got an oem ls gasket. has anyone heard of boring a b18b1 .50 over and re-sleeving it??
Old May 11, 2011 | 11:22 AM
mouab18c1's Avatar
No you don not need to sleeve it at 81.55mm. Anything pass 82mm would require sleeves.
Old May 11, 2011 | 11:50 AM
Hidenplanvew's Avatar
seen OEM headgaskets hold 800whp
cgaleema
Apr 28, 2011 04:52 PM
young geezer
Dec 16, 2010 09:04 PM
ls_bitik
Jul 9, 2007 08:54 AM
gowyeng
Feb 9, 2005 06:36 AM
Turboteggy
Mar 12, 2004 12:16 PM
