Another abs delete question. searched.
Old May 12, 2011 | 05:09 PM
luvmihatch's Avatar
Default Another abs delete question. searched.
I know what i need.
the rs lines, 4040 valve, mc booster set up, etc etc
does any one have the part number from acura for these. there isnt an acura around my house and i dont wanna order the wrong ones.
thanks in advanced.
Old May 12, 2011 | 05:44 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Another abs delete question. searched.
www.hondapartsunlimited.com
Old May 12, 2011 | 05:53 PM
94VTEC2TONE's Avatar
46360-SR3-A02 , 46321-ST7-A00 , 46320-ST7-A00 , 46310-ST7-A00
Those are the 4 lines you will need. acuracarland.com. Fast processing took only 2-3days man
Old May 12, 2011 | 05:54 PM
and no you do not need the rs master and booster dude, keep the 1inch master(i believe thats the size)
Old May 13, 2011 | 10:26 AM
luvmihatch's Avatar
o ok ill look into that.. iwas gonna upgrade to a s2k mc. ijust thought the stockone still had teh abs port on the side.
thanks for the fast responce guys. took me forever to not find the part numbers
Old May 13, 2011 | 11:06 AM
Dave-ROR's Avatar
Get a used prop valve. You have to cut a stock line and a new one to move the fittings over on one end, and flare the new line once the fitting is on there (I just paid a shop to do that part). The rest is annoying to deal with, but not hard.
Old May 13, 2011 | 12:21 PM
luvmihatch's Avatar
so i have to extend on of the rear brake lines. and i orderd a new prop valve with the lines. not worried about the cost it was only hundred bucks.. easier to order new then source on down on here lol.
Old May 13, 2011 | 12:27 PM
TypeRMOBBiN209's Avatar
is this a 94-97 integra or 98-01?
Old May 13, 2011 | 01:16 PM
no the rear brake lines are bolt right in. What he is referring too is cutting one line from the prop to the master because the fittings is too small, just cut it and reflar it shouldnt take no time at all. Im also ordering a new prop valve dont wanna old *** **** after doin all the brake line work.
Old May 13, 2011 | 03:44 PM
luvmihatch's Avatar
97.
Old May 13, 2011 | 11:35 PM
da6xsi06's Avatar
you might want to hit up alan at crx_itr@yahoo.com he sells full abs delete kits at www.g2ic.com with all the harware youll need for a direct bolton..
here is a link
http://forums.g2ic.com/showthread.ph...ght=abs+delete
Old May 14, 2011 | 01:19 AM
lindapaul's Avatar
thanks for the information i would help me a lot.......
Old May 14, 2011 | 01:43 PM
http://www.team-integra.net/forum/19...val-guide.html
trm4life
Apr 27, 2017 05:28 AM
NotoriousJJE
Feb 16, 2012 10:41 AM
maxogsr
Apr 24, 2009 04:58 PM
dc4teg95
Feb 23, 2009 04:15 AM
Eluzion
Apr 7, 2004 08:54 AM
