shaking under acceleration..
Old May 4, 2011 | 02:42 PM
8dxhatchy8's Avatar
Default shaking under acceleration..
so i have a 95 LS coupe 5 speed..just lowered on coils, when im driving around town its perfectly normal, never shakes..but after driving for about 15 or so minutes on the highway in fifth gear just cruisin about 60-65 it will start to shake and shimmy and you can feel it in the gas pedal as well .
but ONLY when i accelerate, not when i brake or when im at a constant speed...anyone know whats up? its pissin me off...thanks.
Old May 4, 2011 | 04:51 PM
dntnedvtec's Avatar
Default Re: shaking under acceleration..WTF!
Wheels need balancing....Car needs alignment. Or your lug nuts are loose.
Old May 4, 2011 | 04:55 PM
8dxhatchy8's Avatar
i just got new tires mounted and balanced
Old May 4, 2011 | 05:10 PM
dntnedvtec's Avatar
hhrrrmmmm........interesting. Only when you acclerate....Worn bushings?
Old May 4, 2011 | 05:12 PM
fcm's Avatar
fcm
Old Fart
Did you get a wheel alignment after you lowered it?
I would have the shop that did your tires recheck the balance, maybe a weight fell off. 94
Old May 4, 2011 | 05:33 PM
dntnedvtec's Avatar
FCM, I was going to say the same thing, but OP mentioned that its only under load. cruising is not affected.
Old May 4, 2011 | 06:11 PM
TheAsian's Avatar
I would say start by checking axles and axle nuts.
Old May 5, 2011 | 12:00 AM
4DRmafia's Avatar
Check axles, it happen to me and came to find out it was a bent axle on my passenger side.
Old May 5, 2011 | 02:54 AM
IN VTEC's Avatar
Inner cv joint is a common culprit.
Old May 5, 2011 | 03:46 AM
8dxhatchy8's Avatar
yea i noticed my passenger cv boots are both ripped...time for a new axle im thinking
Old May 5, 2011 | 06:48 AM
4DRmafia's Avatar
Try it and let us know how it goes.
Old May 5, 2011 | 03:15 PM
8dxhatchy8's Avatar
for sure..well on the way to and back from work, which is 23 miles from my house it didnt shake at all...its really random when it happens
Old May 5, 2011 | 04:29 PM
BoltonGSR's Avatar
My integra shook like that when accelerating, it turned out to be an axle. I payed the price for getting an autozone axle. Not saying for sure its the problem but it was for me.
Similarly,
My gf had this problem and it turned out to be her wheel bearings.
Isnt there a way to test the wheel bearings by jacking the front wheels up slightly and prying on them with a crow bar?
Old May 5, 2011 | 05:31 PM
8dxhatchy8's Avatar
im not sure how to test, guess ill ask google
Old May 7, 2011 | 06:04 PM
8dxhatchy8's Avatar
so i took a 140 mile round trip drive today and it shook off and on, but when it was shaking if i took a left turn around a curve it shook worse and when i went around a right curve it completely stopped!! ??
Random.Hero
Oct 3, 2007 09:55 AM
gloryhog
Feb 5, 2004 05:52 PM
wizzards581
Jun 19, 2003 06:29 PM
DanielLaruso
17
May 11, 2003 08:11 AM
wdyno
Apr 16, 2002 11:13 AM
