94 integra power problem... stumped!!
Old May 13, 2011 | 02:41 PM
lattimer2012's Avatar
Default 94 integra power problem... stumped!!
lastnight my girlfriend was driving the car home and she lost pwoer to the motor so she costed then the motor shut off..... no the car wont start changed the dizzy and main relay both out of running cars but still will not start... no fuses are blown and fuel pump is turnning on... i am out of ideas..
Old May 13, 2011 | 03:23 PM
EJ1_CRIS_909's Avatar
Default Re: 94 integra power problem... stumped!!
Are the dash lights dim? If so could be an alternator. Check the charge on the battery it could be that too. Those are more "common" things it could be. It could be many things, but its good to rule out the easiest first.
Old May 13, 2011 | 03:34 PM
nemesis25's Avatar
Check timing and timing belt.
Old May 15, 2011 | 12:04 PM
timing is on... and changed.. dissy. main realy. and ecu.. just got new ignition switch if not that i dont knwo what else it could be.. thanks guys!
Old May 15, 2011 | 12:19 PM
el crapitan's Avatar
jesus. stop buying/changing parts. figure out the problem first. or at least narrow it down.
check for spark. if you have spark, check for fuel pressure
aeon117
Aug 10, 2010 09:36 PM
lao-boy503
Jan 26, 2010 08:32 PM
louevilhatch
Sep 22, 2007 04:45 PM
dschultz226
Dec 5, 2006 09:22 AM
2000si
Dec 15, 2002 07:22 PM
