Compression Spec on an 94 LS
Old Dec 5, 2004 | 08:16 PM
ekcivicphx's Avatar
Default Compression Spec on an 94 LS
I searched for specs on this and couldn't find them. What are the compression specs for a 94 B18B? I saw on the records of this car i just bought that they were 160 across the board...On my old civic, i had 210 across the board, which was good and the ones for my teg seemed a bit low. Any help would be appreciated. Thanks, guys.
Old Dec 6, 2004 | 10:38 AM
pushinlsteg's Avatar
Default Re: Compression Spec on an 94 LS (ekcivicphx)
I believe 175-180 across the board for stock LS's...mine are 175.
Old Dec 6, 2004 | 11:06 AM
hybrid_vtec's Avatar
Default Re: Compression Spec on an 94 LS (pushinlsteg)
B18B
Standard: 199 PSI
Minimum: 135 PSI
Max Variation between Cylinders: 28 PSI
Old Dec 6, 2004 | 12:08 PM
95lstegman's Avatar
my compression is 175 across the board +/- 3 or so. the block has 175k on it and has never been touched since it left japan in june of '94. and by the way, that's 175psi with the throttle closed. you're supposed to be flooring it when you test compression, so i'm sure mine easily hits 200 flooring it.
LonnyEnds
Jul 2, 2014 07:57 PM
youknowimwhite
Apr 6, 2007 05:16 PM
MRXMUFFIN
Jan 29, 2004 04:11 PM
badcabala
Mar 23, 2002 02:04 PM
