help me decide yo!
i think my apexi N1 is too showie, thinking about getting a spoon N1 because it looks less modified. thinking switching just the axle back though. is there any difference prefomance wise between the two? plus will it bolt up to my apexi b-pipe. if i remember correctly the apexi diameter is 60mm and the spoon is 60.5mm, what do you guys think i should do
Performance wise i'd imagine the difference between the 2 are little to none, as with most canister style exhausts on the market today, especially on an N/A car the differences between them are minimal. Biggest difference between the 2 would be sound. As for the fitment, sorry cant help you with that.
since i can get a silencer that doesn't matter much. but i think the spoon was made to fit stock pipes not sure, if thats the case i think there would be a problem bolting up to the apexi pipe. does anything know?
This has all your answers about the Spoon N1.
http://www.team-integra.net/fo...earch
But to answer your questions quickly.
Yes, it will only bolt-on to a stock B-Pipe, and if you use your Apexi B-Pipe it will need modifying.
Secondly, performance should be negligible, since the Apexi Piping is 60mm and the Spoon Piping is 60.5mm.
Third, the Spoon silencer really ruins the throttle response, so inless your highly sensitive to sound, you may want to learn to live w/ the loudness.
Personally, I would just keep the Apexi N1, or for a few $$$ get the Apexi World Sport ($400 retail vs $350 retail for Spoon N1 + ~ $40 to moddifying to fit), but you would have to live with lower performance gains.
Ovals are sick but if you want to make sure the ovals on the side it just looks better rather than in the middle making look like a stock one just a thought but ethire way its what you like
AllMotorITR
Jan 2, 2002 04:13 AM
