Alignment problem?
Old Jan 17, 2005 | 09:49 PM
BlackGS01's Avatar
Default Alignment problem?
I recently got my Teg back from a body shop because I had gotten into an accident. Everything seems fine about the car but the steering wheel seems a bit, crooked. When I'm going straight on the road the steering wheel is turned slightly to the right, even though the car is going straight and if I try to straighten the wheel, it starts to slowly veer off to the left. Is this an alignment problem or something else? I'm about to call the shop tomorrow to see but wanted to see if you guys knew anything and if there was anyway to fix it.
Old Jan 17, 2005 | 09:53 PM
.water's Avatar
Default Re: Alignment problem? (BlackGS01)
yes alignemt..my moms are does that too..(2 lazy to go get fixed)
when steering wheel is stright .car goes to right..so i have to turn to left little bit to go stright..lol
Old Jan 18, 2005 | 01:00 AM
OneDirection's Avatar
You either
A: are out of alignment
or B: when the body shop aligned your car they didn't center the wheel. It's a fairly simple procedure in the service manual.
easyFOsheezy
Aug 25, 2010 12:26 PM
teg_dc2
Mar 13, 2009 12:35 PM
duyfash0
Jan 8, 2008 04:44 AM
Playa_FL
Mar 10, 2006 07:54 AM
dyases
Jun 10, 2004 08:56 PM
