Need Injectors
Old Jan 19, 2005 | 05:37 PM
gsrboi80's Avatar
Default Need Injectors
Ok i need to get a set of fuel injectors. After a couple hours of diagnostics it turns out I'm getting leak down through one of them. Accel sells them for GSR's that flow about 10% better but all that I can find is for up to 97 GSR's are they different than my 00 GSR's injectors? I need imput guys please
Old Jan 20, 2005 | 05:37 PM
gsrboi80's Avatar
Default Re: Need Injectors (gsrboi80)
bump
Old Jan 22, 2005 | 04:44 PM
gsrboi80's Avatar
bump
Old Jan 22, 2005 | 05:28 PM
3.504's Avatar
they are the same plug, just make sure you get obd2 plugs (96-up), if not the injector harness pigtail wont plug up to the injector, in that case, swap injector pigtails to obd1's if you get obd1 plugs. after obd0 injectors on b-series are all still 240cc and they're high impedence, old style (b-series obd0) was the low impedence where you need an in line resister box going to the injector pig tails.
anyways, they'll do.
Old Feb 3, 2005 | 05:03 PM
gsrboi80's Avatar
Default Re: Need Injectors (3.504)
so the accel's will work then cool
Old Feb 3, 2005 | 05:09 PM
Kapman38's Avatar
I have a set of OEM OBD 2 240cc Teg injectors.. just make me an offer, (actually have 2 sets, 1 OBD-1, and 1 OBD-2)..
vlc92189
21
Mar 6, 2009 12:06 PM
.BigSexy
Mar 21, 2008 02:39 PM
fortynineR
Aug 30, 2007 03:08 PM
Turbo_y8
Jan 20, 2006 09:19 PM
Chuckles
Nov 14, 2001 02:22 PM
