Compression Numbers
Old Oct 13, 2005 | 10:16 AM
iTzKeviN's Avatar
Default Compression Numbers
hello everyone. tomorrow, i plan on doing a little compression test just to see how the engine is holding up. i was wanting to know what numbers should be expected for a 1992 Integra GSR.. thanks a lot and have a nice day.
Old Oct 13, 2005 | 11:47 AM
DC494LS's Avatar
Something even all the way across. Expect a little difference in numbers if you have a lot of miles on the motor.
Old Oct 13, 2005 | 12:50 PM
iTzKeviN's Avatar
Default Re: (DC494LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC494LS &raquo;</TD></TR><TR><TD CLASS="quote">Something even all the way across. Expect a little difference in numbers if you have a lot of miles on the motor.</TD></TR></TABLE>
well..i have around 166,000 miles on it so far. should i expect numbers to be between 180-200?? cuz i think i saw that gsr's were suppose to be around 200-210, but those were dc2's..iono if its suppose to be different from mine or not
Old Oct 13, 2005 | 01:52 PM
TrueUntilDeath.com's Avatar
Default Re: (iTzKeviN)
mine were
210 200 200 190
98 Stock ls.
did the test at about 94k miles
Old Oct 13, 2005 | 01:59 PM
h4x's Avatar
h4x
How much is it costing you?
If you are around 180 you should be fine.
Old Oct 14, 2005 | 04:38 PM
k e v i n's Avatar
anything between 170 and 210 just make sure theyre all almost even
Old Oct 14, 2005 | 05:25 PM
redDAinteg's Avatar
Default Re: (k e v i n)
I have 162k miles on my LS and when I did a compression test a couple of months ago, I got around 145 - 155 all across. Kinda low, but fucc it, still runs strong.
Old Oct 14, 2005 | 05:50 PM
TurdBlown Teg's Avatar
i thought the ls min was 135 and the max for an ls motor was 185 or something like that?
Old Oct 14, 2005 | 09:01 PM
tegG2's Avatar
Default Re: Compression Numbers (iTzKeviN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k e v i n &raquo;</TD></TR><TR><TD CLASS="quote"> 170 and 210 just make sure theyre all almost even</TD></TR></TABLE>
jdmitrna
Jul 5, 2008 04:48 PM
Mr.OB*GYN_Rhett
Aug 17, 2006 10:54 PM
silverboost
Dec 16, 2005 02:59 PM
Chubz
Honda S2000
Nov 28, 2005 10:23 PM
peel17
May 29, 2005 01:19 AM
