Starter problem?
Old Oct 11, 2005 | 10:58 AM
bboyoracle's Avatar
Default Starter problem?
So lately i have been having trouble starting my car? I dont have to try numerous times. Just turn the key once but def sounds like it takes some time for it to start. And sometimes makes a screeching noise once it starts.
On top of that when i turn the car off i hear a ticking sound slowly whining down. Like something spinning? What do you guys think, thanks in advance.
Old Oct 11, 2005 | 11:15 AM
SOHCVTECx2's Avatar
check to make sure your starter it hooked up properly or the screws are all tight, if its loose it can make whiny noises. If that is still not the case, then replace it with a new starter, also check your ground make sure its bolted down, and the small cable that connects to the starter. Those and let me know how it goes.
Old Oct 11, 2005 | 12:08 PM
BrooX's Avatar
Default Re: Starter problem? (bboyoracle)
You may have issues with the PCM Valve. Check your electrical bro, it is not as harmless as we all think it is. Other than that it sounds like it is most likely your starter but get professional(a trusted local shop) advice and see how to fix the problem.
Old Oct 11, 2005 | 12:45 PM
bboyoracle's Avatar
Default Re: Starter problem? (DA9GUY-637)
i just drove the car in so i'ma wait til everything cools down b4 i check it. But will def take it to a shop. If you guys have any more suggestions let me know thanks!
Old Oct 13, 2005 | 09:28 PM
CrazyHondaBoy's Avatar
Check the ground wire. Perhap it time to replace the starter. Any luck on selling ur car?
Old Oct 14, 2005 | 01:43 AM
bboyoracle's Avatar
Default Re: Starter problem? (CrazyHondaBoy)
we'll see going to show this guy the car tomorrow.
thirty3
Mar 23, 2013 11:14 AM
ThatsTheTruth
Dec 7, 2006 06:40 AM
Race Egr
Jan 31, 2005 01:18 PM
gobblebox59
Sep 4, 2004 09:05 AM
5spdIntegra
Mar 26, 2004 12:54 PM
