92 integra help!
Old Oct 13, 2005 | 12:03 PM
Catastrophy's Avatar
Default 92 integra help!
I have a 92 GS. When I took it to work, left it for 9 hours, came back and it wont start at all. It turns over just fine, but thats about all it does. I thought it might have been because I was low on gas (My e-light was on for awhile) but I filled it up and that didn't solve any problems. When I turn it over I smell gas, so I wouldn't think it's the fuel pump. The last 2 tanks before this I got about 30% less MPG though, so I don't know whats up with it. I tried to push start it and that didn't work either Any ideas?
Old Oct 13, 2005 | 12:18 PM
92DAIntegraXSI's Avatar
Default Re: 92 integra help! (Catastrophy)
check to see if you have spark the da integras are known for the distributor going bad being they had a recall on them it could also be a ignitor or a coil but check to see if you have spark do you have a check engine light?
Old Oct 13, 2005 | 01:17 PM
BlackLudeSi's Avatar
Default Re: 92 integra help! (92DAIntegraXSI)
If you can smell gas its a good bet you car is getting fuel, and you probly have air, so that leaves spark. Check for spark at the plug and at the dizzy, should help you figure it out quicker
Old Oct 13, 2005 | 01:40 PM
BrooX's Avatar
Wow that sucks.....Check and see if you need a tune-up because that is what it sounds like. If not maybe you will need the timing belt replaced w/water pump. This problem of yours just sounds like maintanence issues. You may even consider a compression test.
Old Oct 13, 2005 | 03:18 PM
TheBobFather's Avatar
Default Re: 92 integra help! (DA9GUY-637)
pig ^^^^^
elite01
Honda Civic (2001 - 2005)
20
Nov 21, 2009 04:00 PM
92 teggy
Jul 7, 2009 06:39 PM
xfrankx
Jan 26, 2005 11:10 AM
diewX3
Jan 9, 2005 09:01 PM
Cabby89
Oct 17, 2004 08:34 PM
