oil pump replacement
Old Jul 17, 2006 | 03:23 PM
Turbo_TONY's Avatar
Default oil pump replacement
do you have to pull the engine to replace the oil pump? If not.whats the easiest way?
Old Jul 17, 2006 | 05:13 PM
deeweewoo's Avatar
Default Re: oil pump replacement (Turbo_TONY)
No you do not. The easiest way is to take it to a mechanic. but if you dont want to do that just take off everything on that side of the motor and go at it.
Old Jul 17, 2006 | 08:05 PM
Calsonic's Avatar
You will need to take off the belts and crankshaft dampener.
Old Jul 17, 2006 | 08:31 PM
ITR#132's Avatar
Default Re: oil pump replacement (Calsonic)
And you will need to remove header, oil pan, oil pickup, windage tray
Old Jul 18, 2006 | 07:59 AM
deeweewoo's Avatar
Default Re: oil pump replacement (ITR#132)
Yep anything and everything near the oil pump.
Old Jul 18, 2006 | 11:02 AM
Turbo_TONY's Avatar
Default Re: oil pump replacement (deeweewoo)
Ive got a 94 LS.. can i throw in a gsr oil pump without and modificatoins?
Old Jul 20, 2006 | 11:57 PM
dohcgarage@714's Avatar
yea it will fit no problem all b series oil pumps are the same but it would be better to go with a b16 or a type r they give you more psi than gsr or ls
Old Jul 21, 2006 | 08:15 AM
LSVTEC408's Avatar
ya u could use any vtec oil pumps, but if u dont know what u doin better have someone with experience do it, basically u have to remove oil pan,windrage tray,timing belt, top mount,crank pulley, all belts..it be about a 4 hour job for me...
allmotor_guys
Jul 11, 2009 07:05 PM
Turbo_TONY
Jul 26, 2006 11:32 AM
caspers_hatch
Nov 12, 2005 11:37 PM
Mefain
May 16, 2003 09:02 AM
