Upper control arm?
Old Jul 16, 2006 | 11:18 AM
Backk InTheDA's Avatar
I hate everything
Default Upper control arm?
I've always been curious if an aftermarket upper control arm was made for the G2 integra's. I've never been able to find one.
Something like this. I'm aware of how to get the camber corrected on the car, because the picture above is to adjust the camber. Just wondering if anything like that unit is made for the G2 integra's.
TIA
Old Jul 16, 2006 | 12:04 PM
projectTeG's Avatar
vision makes one for our cars, but they are only negative camber adjustable.
Old Jul 16, 2006 | 01:00 PM
I hate everything
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">vision makes one for our cars, but they are only negative camber adjustable.</TD></TR></TABLE>
Would I be able to use something like this to correct what you just stated?
http://www.modacar.com/product....html
Old Jul 16, 2006 | 01:24 PM
projectTeG's Avatar
Default Re: (Backk InTheDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Backk InTheDA &raquo;</TD></TR><TR><TD CLASS="quote">Would I be able to use something like this to correct what you just stated?
http://www.modacar.com/product....html</TD></TR></TABLE>
if your not to low then those are good, but im dropped about 3 inches and those balljoints took away alot of my UCA to shock tower clearance and the knock around alot. im going back to stock a soon as i can!
Old Jul 16, 2006 | 01:28 PM
I hate everything
if your not to low then those are good, but im dropped about 3 inches and those balljoints took away alot of my UCA to shock tower clearance and the knock around alot. im going back to stock a soon as i can!</TD></TR></TABLE>
Thanks for the help man, really appreciate it. But do you have website to where I can check out those vision control arms? I looked at the sponsors section, and was unsuccessful.
Old Jul 16, 2006 | 02:04 PM
BustedTeg's Avatar
skunk2 doesnt make one for a da? thats odd
Old Jul 16, 2006 | 03:59 PM
projectTeG's Avatar
Default Re: (BustedTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BustedTeg &raquo;</TD></TR><TR><TD CLASS="quote">skunk2 doesnt make one for a da? thats odd</TD></TR></TABLE>
no.
OP:
you can go to jhpusa.com and check them out.
Old Jul 16, 2006 | 04:32 PM
I hate everything
no.
OP:
you can go to jhpusa.com and check them out.</TD></TR></TABLE>
Thank you!
Old Jul 17, 2006 | 03:38 AM
RHDintegXsi's Avatar
no one to my knowlege makes an adjustable upper control arm to correct camber on the DA. there simply isnt enough room. last i heard omniman was working on designing one but ran into clearance problems also. from what i hear the best we can get in our da's are to use spc adj ball joint and hammer the inner fender for clearance.
i myself am dropped well more than 3 inches and have given up on correcting my front camber.
ChevelleSSLS6
Mar 10, 2009 01:05 PM
lambertincorp
Suspension & Brakes
Oct 7, 2007 10:41 AM
redDA90
Suspension & Brakes
Jul 29, 2006 03:20 PM
..::91TEG-G2::..
May 23, 2004 01:53 PM
RineRacing
23
May 30, 2002 06:06 PM
