smog question
Old Jul 18, 2006 | 02:23 AM
kDA's Avatar
kDA
Default smog question
I have a bone stock 91 RS, nothing done to the motor and runs fine and clean, I'm sure it will pass my smog test only except for the fact that I dont have my Speedo cable plugged in because I swapped clusters and wasn't able to get the speedo cable into the cluster cause my hand is too big.
Anyway my check engine light turns on due to this, I've been told its the speed sensor, but I was wondering if I have to get this fixed in order to pass test only smog, or could I just take it in like that.
The check engine light only comes on when I let off the gas in 4th and 5th gear while on the freeway or high speeds.
Any advice is appriciated thanks.
Old Jul 18, 2006 | 10:38 AM
kDA's Avatar
kDA
no one?
Old Jul 18, 2006 | 10:42 AM
Lan's Avatar
Lan
Default Re: smog question (kDA)
This is a really good question, I don't know actually. I think they might say you have a CEL but it is passes the sniffer and visual I think it would pass.
Old Jul 18, 2006 | 12:19 PM
roadrunner's Avatar
A CEL showing is an automatic fail.
Old Jul 18, 2006 | 04:44 PM
stpdfasthonda925's Avatar
when they see the check engene they wont even put it on the rack shitty i kno pull the light
Mike457
Honda Civic (2001 - 2005)
May 7, 2016 10:05 PM
civicSF98
Nov 3, 2009 02:33 PM
Blammo300
Dec 7, 2005 04:45 PM
SOLO1racer
Jan 26, 2005 10:19 AM
