NEED HELP BOGGING
Old Jul 18, 2006 | 10:48 AM
DB1_559's Avatar
Default NEED HELP BOGGING
ok my 93 ls will not go pass 6000k it runs strong untill i get to 6k and then it bogs out like my powers gone what can it be.
ps when im in the driveway at idle it will go to 7200k redline good no lag
help me thanks
Modified by jdmboi86 at 1:46 PM 7/18/2006
Old Jul 18, 2006 | 12:56 PM
96tegls2dr's Avatar
Default Re: NEED HELP BOGGING (jdmboi86)
i wont rev past 6k under load probably because its not getting enough fuel. i would check your TPS and see if its giving the correct signal. if so move to the injectors maybe run some clearner through them. and also see if you cat smells at all. if it smells it could be going bad and causing some restriction under load.
Old Jul 18, 2006 | 01:08 PM
DB1_559's Avatar
bump i just gonna get a new cat cause i got to smog my car soon
Old Jul 18, 2006 | 02:43 PM
stpdfasthonda925's Avatar
try a tune up
Old Jul 18, 2006 | 02:47 PM
96tegls2dr's Avatar
if the cat isnt messed up then your just wasting your money
Old Jul 19, 2006 | 08:36 AM
DB1_559's Avatar
DID A TUNE UP ALREADY
Beto760
May 15, 2011 03:26 PM
zzzzzzzz
12
Aug 2, 2008 11:46 AM
dafuzzbudd
23
Jan 31, 2007 09:58 PM
Chinchilla
Jul 21, 2004 02:49 PM
k-man
Feb 3, 2003 02:58 PM
