Compression Test Results
Old Jul 25, 2006 | 11:39 PM
SoEvoL's Avatar
Default Compression Test Results
it goes as follows ordering from drivers side first
stock block/head oem gaskets
210, 190, 195, 215
i bumped it 4 times each, on the first one i noticed my spark plug was covered with white corrosion, which means lean correct, and my plug seals are fubared on the 2nd one because it had oil on the sparkplug. i expected the results to be worse having over 135k miles on the motor, (20k of which i owned and it was supercharged)
Old Jul 26, 2006 | 02:25 AM
lVlemphizStylez's Avatar
Default Re: Compression Test Results (SoEvoL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoEvoL &raquo;</TD></TR><TR><TD CLASS="quote">it goes as follows ordering from drivers side first
210, 190, 195, 215
i bumped it 4 times each, on the first one i noticed my spark plug was covered with white corrosion, which means lean correct, and my plug seals are fubared on the 2nd one because it had oil on the sparkplug. i expected the results to be worse having over 135k miles on the motor, (20k of which i owned and it was supercharged)</TD></TR></TABLE>
the results lead me to believe headgasket...the two cylinders next to each other with lower compression usually comes up with a head gasket issue...
Old Jul 26, 2006 | 07:35 AM
SoEvoL's Avatar
Default Re: Compression Test Results (lVlemphizStylez)
good thing i got this omni power valvetrain that needs to be installed, going to once again buy all oem gaskets and go from there.
phaphon
24
Apr 13, 2017 09:00 AM
nengx07
20
Feb 6, 2009 08:10 PM
motormike40
Apr 7, 2007 03:02 PM
DriveSideWays
Aug 22, 2004 07:19 AM
