Throttle position sensor???
Old Apr 25, 2010 | 09:35 AM
airikkCRX's Avatar
Default Throttle position sensor???
I have a jdm b16 motor the problem is when you start to give the car gas it seems jerky and when you let off the gas it's jerky. I was wondering if it's the throttle position sensor? How could I check it to see if that's the problem? Then if it does need to be replaced where can I find the right sensor?? Thanks for any help
Old Apr 25, 2010 | 10:06 AM
koss1229's Avatar
Default Re: Throttle position sensor???
Get a multimeter and check the voltage of that sensor. It should be 0.5v in closed and 5v in wide open throttle. Also, check the range from 0.5 to 5. Should go smoothly while opening.
I never tried, but people say, TPS is the same for all our cars. Even one from civic should work.
Good luck fixing it!
Old Apr 25, 2010 | 11:23 AM
VPDave's Avatar
If the tps is bad the check engine light should pop on...some times the speed sensor can do that to if its a electronic speed sensor.
gripek
Honda S2000
12
Feb 22, 2012 10:08 PM
airikkCRX
May 15, 2010 06:47 PM
geogal84
Oct 23, 2007 02:41 PM
christianscrx
Apr 20, 2005 08:29 AM
turboxsi
Jun 16, 2003 08:13 PM
