NEED b20vtec Check engine help...
Old Apr 25, 2010 | 12:20 PM
B20vtcdrewskee's Avatar
Default NEED b20vtec Check engine help...
On my 96 gsr with 01 b20z bottom end and gsr vtec...the check engine light came on after i had changed the radiator to a smaller LS radiator. When i checked the light using a paper clip it blinked 9 slow and 2 fast...p092...i cant find out anything about this code and need to figure it out. Anyone come across this before?
ITR radiator support and hood wanted
Old Apr 25, 2010 | 12:37 PM
slomofo's Avatar
GDD Member
Default Re: NEED b20vtec Check engine help...
You're counting the blinks wrong and P-Codes can't be found with a paperclip.
Old Apr 25, 2010 | 12:41 PM
oh how do i do it? i went to autozone cuz nobody is open today and pepboys couldnt figure out how to read the code...the autozone dude put the paperclip and then the check engine light would blink 9 times slowly and twice fast...
Old Apr 25, 2010 | 09:28 PM
ruffrhyder's Avatar
92 is an evap system insuficient purge flow code. Reconnect all the evap canister vacuum lines and solenoid. Also might wanna check for vacuum leaks.
Old Apr 30, 2010 | 05:36 PM
Thanks but an hour after i disconnected the battery and it hasnt came on since!
67tj67
Oct 4, 2018 11:38 AM
Chujdm
Engine Management and Tuning
Nov 17, 2012 12:03 PM
HBADGE
Aug 9, 2006 11:41 AM
s2kc's
Mar 12, 2005 08:22 AM
redlude97
Jan 4, 2005 01:17 PM
