b20 overheating issues
Old May 7, 2010 | 09:02 AM
prime-R's Avatar
Default b20 overheating issues
So I have a 92 integra with a 98 b20 p8r,the car is overheating,my thermostat is new,water pump is new,hoses are new,I ran the fan direct to see if it would help and nothing still overheats,there is no clog I flush the cooling system and radiator,im out of ideas of what it could be.Anybody have an idea of what it can be?any help or suggestion?
Old May 7, 2010 | 01:09 PM
coolAcy91's Avatar
Default Re: b20 overheating issues
catalyst Converter? maybe there is a bigger problem, is something wrong with the exhaust part of the car??
Old May 7, 2010 | 01:18 PM
mouab18c1's Avatar
Check for leaks.
Old May 7, 2010 | 01:21 PM
DumaDA's Avatar
could be a blown headgasket
is it overheating at any certain times, driving conditions? etc
Old May 7, 2010 | 01:47 PM
dntnedvtec's Avatar
Are you blowing smoke?
I have the same issues....Its not over heating, but it runs hot. A little past the center.
Old May 7, 2010 | 02:07 PM
DumaDA's Avatar
it runs that way constantly? it might be the incorrect thermostat if its constantly at a high temperature but doesnt over heat
Old May 7, 2010 | 04:07 PM
prime-R's Avatar
No leaks,no smoke,it ran fine till one day a week ago it started to overheat and I slightly reved it and the arrow came back down,till now it started overheating to the point I will not go down.I don't drive hard I barely push the car,I have never let it overheat to the red line I've always just shut it off
Old May 7, 2010 | 04:27 PM
DumaDA's Avatar
well i would double check on your radiator unless its new, also probably double check your thermostat to see if it opens and closes properly, also make sure your radiator is working properly, i had the same problem you're having on my old ls motor, i replaced the thermostat and it stopped, it would only over heat when the car was on and i was parked and that was because my fan wasnt turning on
Old May 7, 2010 | 04:30 PM
prime-R's Avatar
Old May 7, 2010 | 04:34 PM
prime-R's Avatar
I tested the thermostast in boiling water works fine and to double check I took it off and ran it with no thermo stat,also I ran the fan direct to see if that was the issue but it still overheated
Old May 7, 2010 | 07:00 PM
mouab18c1's Avatar
Check your radiator cap, check under your oil cap just to make sure its not a headgasket.
Old May 8, 2010 | 01:23 PM
dntnedvtec's Avatar
huh, I drive hard on my car, it cools down to the center of the gauge, but when i continue to drive it normally, it begins to run hot, not over heat, but runs hot...I am guessing a incorrect head gasket? I have a P8R head, with a LS block, and I am using a LS headgasket. Hmmmm...It did line up with the block, but not the head. the head gasket holes were smaller than on the head. I now wonder if the head gasket was too small thus not allowing enough coolant flow causing the sensor to read hot??????...
oderfla90
Apr 27, 2017 09:15 AM
kurs
Oct 15, 2009 07:41 PM
JAYDmManny1331
Jul 20, 2009 07:39 AM
FAWKeveryb0dy
Aug 10, 2005 05:58 PM
B20TDC2
Jul 30, 2005 07:31 AM
