Alignment Problems...is something bent?
Old Oct 3, 2001 | 06:08 PM
BeyondRedline's Avatar
Default Alignment Problems...is something bent?
Well, I got in an accident a little while ago and my camber and toe was really bad in one wheel. I go and get an alignment and realized exatcly how bad it was.
Front Left Right
Camber -2.3 -2.1
Cross Camber -0.2
Toe 0.01 -0.02
Total Toe -0.01
Set back 0.28
Rear
Camber -5.4 -1.7
Toe 0.97 -0.10
Total Toe 0.87
Thrust angle 1.07
My rear left wheels is obviously really bad. Do I have a bent lower control arm or is it something else? How do the rest of my settings look? Can someone please shed some light on what is wrong? With that much neg. camber I'll be wearing out my Azenis pretty quick
Old Oct 3, 2001 | 06:13 PM
dustin's Avatar
Default Re: Alignment Problems...is something bent? (BeyondRedline)
Something in the rear left is bent for sure
Dustin
Old Oct 3, 2001 | 07:16 PM
ALF's Avatar
ALF
-5.4 camber = WHOA
ANYTHING can be bent back there. If it's the LCA, it won't cost much, but I'm pretty sure there are more things bent back there.
Old Oct 3, 2001 | 07:20 PM
dustin's Avatar
Default Re: Alignment Problems...is something bent? (Dozed)
The rear LCA is pretty strong. The trailing arm usually bends first.
Dustin
Old Oct 3, 2001 | 07:25 PM
Anything can be bent? Ahh, I was hoping it would be the LCA since it's only like 70 bucks. Is there anything in specific I should check out? Dustin said trailing arm, what other possibilities are there? I just want to know what to look for.
BTW with 5.4 degrees I finally feel like I fit in with those slammed teggies. I'm cool like them now too!
Old Oct 3, 2001 | 07:32 PM
dustin's Avatar
LCA and trailing arm are the only 2 things that bend.
When I decided to do this to my integra http://imglib.************/index.cgi?cmd=viewcat&id=25 , I bent both the LCA and trailing arm. The LCA was barely bent and the trailing arm was really destroyed.
BTW those pics are from 2 separate wrecks. I am referring to the wreck with the bent right side suspension... not the one with the "door ding" in the rear left quarter panel.
Dustin
Old Oct 4, 2001 | 12:56 PM
Default Re: Alignment Problems...is something bent? (dustin)
Looks like you were right, went to my mechanic today and he said the same thing. Neither one looks bent so we really don't know which one to replace. Is there any way to tell either my looking at it or measuring it? If not I guess I have to replace both.
Also, it really doesn't look that hard to do, should I try to do it myself or just let him handle it?
Old Oct 4, 2001 | 01:03 PM
dustin's Avatar
It matters which part you get. If you can find a trailing arm with the hub together (used or something) it is really easy to swap it out yourself. If you just get the trailing arm, then you are going to have to swap over the hub and bearing and it is sort of a pain.
Yeah, the parts never "look" bent. They just are
Dustin
00IntegrAllmotoR
Aug 12, 2009 06:48 PM
ahs2m2
Suspension & Brakes
Jun 6, 2005 12:02 AM
WheAs MaI MojO
Oct 11, 2002 08:06 PM
Yesman
Jan 31, 2002 11:01 AM
keys
Sep 7, 2001 11:21 AM
