Compression Test results:
Old Sep 29, 2001 | 04:47 PM
Zulu888's Avatar
Default Compression Test results:
#1 - 160
#2 - 160
#3 - 160
#4 - 160
this ok on a 72K km car?
Thanx.
Old Sep 29, 2001 | 05:06 PM
DOHC_VTEC786's Avatar
New User
Default Re: Compression Test results: (Zulu888)
I would think thats fairly low.......last i checked i ran a 180 all the way and it had 90km.......i am doing it tommorow and my car has a 119km with basic bolt ons i will let you know how mine turns out
Old Sep 29, 2001 | 05:20 PM
Ricehornet's Avatar
at least they are consistent...
Compression tests usually dont have a specific number because it has to do with more variables than just condition of the engine...
Most GSR's i'd imagine have around 200psi +/-
[Modified by Ricehornet, 9:23 PM 9/29/2001]
Old Sep 29, 2001 | 05:21 PM
non-VTEC's Avatar
did you do it with the engine hot? did you press the throttle all the way while cranking for each cylinder? did you remove the ECU fuse?
try again man 160 seems kinda low. my LS had 180 on all 4 with 120k KM.
Old Sep 29, 2001 | 05:35 PM
D-SPEED's Avatar
Default Re: Compression Test results: (non-VTEC)
my GSR had 235 across the board.....but its a freak for some unknown reason
Old Sep 29, 2001 | 06:03 PM
Zulu888's Avatar
Default Re: Compression Test results: (D-SPEED)
i dunno, the dealer did it
Old Sep 29, 2001 | 06:19 PM
nugget8000's Avatar
New User
If you are really worried I would take it back for a leakdown. This would tell what is leaking where, if anything at all. It could be something as simple as needing a valve adjustment. It could also just be a weak starter motor.
Old Sep 29, 2001 | 09:27 PM
Zulu888's Avatar
Default Re: Compression Test results: (nugget8000)
hmmm, ok, i'm gonna talk to the mechanic tomorrow. would it be because my CAI is kinda loose right now?
Old Sep 29, 2001 | 09:58 PM
nugget8000's Avatar
New User
I wouldn't think that could effect it because when the air is compressed within the cylinder and actually registers on the guage is when all the valves are closed, therefore a leak on the intake shouldn't effect anything. If it was the case that it would effect it then your air filter would screw you every time.
Old Sep 29, 2001 | 09:59 PM
GSlowR's Avatar
ya that's pretty damn low.. i got 225 in cylinders 1 and 3 and 220 in 2 and 4..
Old Sep 30, 2001 | 02:10 AM
ingrate's Avatar
25 Year Member
Default Re: Compression Test results: (GSlowR)
160 all around seems alright, just as long as it's consistent.. that's all you really want. how many times did you crank the motor? i got about 200 all around when i cranked it 5 times, and 235 all around when i cranked it 'til the needle stopped going up
Old Oct 2, 2001 | 09:09 PM
Zulu888's Avatar
Default Re: Compression Test results: (In7egrity)
k, i just asked the mechanic who did the testing and he says this is normal for all honda engines. he says even preludes and civics all have around this #...
he says if i use another guage i may get a higher reading. hmm, maybe i should try that. what's a good guage to get? how much are they? How do you use them? Like how do I actually check my compression?
Thanx.
Old Oct 3, 2001 | 05:01 AM
PROFILES2000's Avatar
i have the craftsman one from sears only $20 seems pretty accurate also
Old Oct 3, 2001 | 05:06 AM
pstreck's Avatar
New User
Default Re: Compression Test results: (PROFILE GSR)
what is a leakdown test? And also how is one performed?
Old Oct 3, 2001 | 07:06 AM
IN VTEC's Avatar
Isn't 160 psi right at teh service limit?
gs-R_swap
Oct 4, 2009 12:12 PM
gtec8285
Jun 24, 2008 01:18 AM
Junkie
Mar 22, 2008 12:21 PM
blacK_Dc4
May 3, 2006 10:55 AM
dirtySOHC's
27
Jun 11, 2002 05:38 PM
