Question about camber...
Old Mar 2, 2002 | 02:33 PM
Pineapple Devil's Avatar
Default Question about camber...
I just put my Neuspeed Sport springs on and my camber is about 1.5 degrees off. Do you think this is enough to need a camber kit? Whats the wear time on this difference of camber settings?
Old Mar 2, 2002 | 02:40 PM
Stop the Beast's Avatar
Default Re: Question about camber... (Pineapple Devil)
I would get one. I had those same springs on my old civic and the front tires definetly wore faster than my rear ( the rear had a homemade camber kit) I had the rears for about 8 months with plenty (60-70%) of tread left; and the fronts went bald inside then I flipped them and they were done for in that same amount of time. Tires: Dunlop SP8000
Old Mar 2, 2002 | 03:26 PM
rjardy's Avatar
Default Re: Question about camber... (brokstar)
yeah get it
there cheaper than tires!
Old Mar 2, 2002 | 05:18 PM
ALF's Avatar
ALF
1.5 degrees negative camber is not bad. Make sure your toe settings are within spec. As long as you don't have more than 2 degrees negative, you'll be fine. Mine is at 2 degrees and I've been rotating tires every 2 oil changes. No problems whatsoever with tire wear.
Old Mar 2, 2002 | 05:20 PM
bullz's Avatar
Default Re: Question about camber... (rjardy)
yeah get it
yeah get it
yeah get it
GET ONE
yeah get it
yeah get it
yeah get it
XplodeTeg
Jul 27, 2010 11:04 AM
climb_on
Jul 1, 2007 01:04 PM
Jesterian
Sep 28, 2006 08:05 PM
Tuesdaynightfever
31
May 24, 2006 06:03 AM
Screamer
Oct 11, 2002 12:18 PM
