reprogramming OBDII?
Old Mar 4, 2002 | 04:16 PM
LOwrestling2001's Avatar
Default reprogramming OBDII?
hi
i'm having cams..valve springs/retainers ...IM installed soon...on my 98 gsr...does anyone know how i can go about getting my vtec Xover changed (for the sk2 IM)...and my rev limiter raised also? i was thinkin along the lines of raising rev limit to 10K so i can put MSD ignition w ignition cut at like 9200 or 9500....on jun2 cams w portflow inners itr outers...any suggestions to get my ECU modded, w/o having to buy 200 dollar harnesses and new ecus?
thanx
Old Mar 4, 2002 | 04:39 PM
eg6ajk's Avatar
Default Re: reprogramming OBDII? (LOwrestling2001)
first reprogramming your OBDII ecu is going to cost more then harness converter + OBDI ecu... your options are either getting a stock 97-8 ITR ecu (since you're going with the skunk2 manifold) but of course the redline isn't high enough so a solution would be vtec controller
next option vtec controller with GSR ecu
third option is get aftermarket JDM Spoon/Mugen/J's racing ecu
remeber for OBDII there is no cheap way unless you go with OBDI ECU...
Old Mar 4, 2002 | 04:45 PM
D-SPEED's Avatar
Default Re: reprogramming OBDII? (eg6ajk)
get hondata
Old Mar 4, 2002 | 04:53 PM
jteasy's Avatar
New User
Default Re: reprogramming OBDII? (D-SPEED)
I tried to get my OBDII reprogrammed, and not even JOTECH knew of anybody that would do it, so I got the OBDI and harness, and jun program instead, it is worth it, and instead of getting just the raised rev limiter, you also get a more effecient program.
Old Mar 4, 2002 | 05:06 PM
t's Avatar
t
...but of course the redline isn't high enough so a solution would be vtec controller...
Vtec controller has no control over the revlimiter of the ecu.
Also the cost of going to OBD1 is cost of ecu($100-$200), cost of harness adaptor($200-$250), cost of reprogram OBD1 ecu($150-$200);
Reprogramming of OBD2 is $300-$400
[Modified by t, 6:12 PM 3/4/2002]
Old Mar 4, 2002 | 05:09 PM
t's Avatar
t
Default Re: reprogramming OBDII? (JTEASY)
There are actually a lot of places that can reprogram OBD2 ecus. All the places that can do custom ecu programs for OBD1 ecu can also reprogram OBD2.
Old Mar 4, 2002 | 05:15 PM
Scary1109's Avatar
Default Re: reprogramming OBDII? (t)
do you have any info on these places, i am looking to reprogram my ecu
thanks
Scott
Old Mar 4, 2002 | 05:25 PM
t's Avatar
t
Default Re: reprogramming OBDII? (Scary1109)
Try dynospotracing.com, They can reprogram all types of ecu from european to japanese, plus they are authorized Hondata dealer.
Old Mar 4, 2002 | 05:58 PM
98SILVERGSR's Avatar
From: I want a 3some with Chasey Lane and Jenna Jameson, Canada
Correct me if I`m wrong, but wouldn`t reprogramming the ECU make it impossible to pass emissions in the future, whereas a OBD1 chip with harness you could just yank off?
Old Mar 4, 2002 | 06:45 PM
t's Avatar
t
Default Re: reprogramming OBDII? (98SILVERGSR)
I dont think you will have a problem with reprogrammed ecu with passing smog, but if you are worried i am sure you can tell the programmer to leave the non-vtec fuel and ignition maps stock and only modify the vtec maps.
Most people who have their ecu reprogrammed have extensive mods such as cams that dont idle right(wont pass smog) and have the reprogrammed ecu correct it to a point were it will idle and pass smog test(maybe )
phish4709
Dec 11, 2006 05:53 PM
auto moto
Aug 10, 2004 12:30 PM
MXPX
Jul 4, 2001 02:25 PM
