Interior questions???
Old Mar 4, 2002 | 02:22 PM
InfamousRS's Avatar
Default Interior questions???
How hard is it to take a 3g integra dash out? I know its a little difficult, but I know it can be done. Also, how do you take the interior pillar peices and peices that surround the rear window? And last, I have access to a sterring wheel puller, is that all I need to take a Integra steering wheel off? Is there anything I need to do to the airbag before removing it? Thanks for all the help!
Old Mar 4, 2002 | 03:10 PM
InfamousRS's Avatar
Default Re: Interior questions??? (BLK94RS)
Anyone?
Old Mar 4, 2002 | 03:48 PM
InfamousRS's Avatar
Oh yeah, I also need to know what is involved in removing the pasenger side airbag?
Old Mar 4, 2002 | 06:01 PM
InfamousRS's Avatar
Comon guys, I need some info, Iv had this up all day!!!!
Old Mar 5, 2002 | 01:37 PM
thejdmkid's Avatar
to pull the dash u need a 12mm an 6 in extiesion, the pillars will just snap off, but becareful not to **** up the roof lineing. the the passenger airbag just dissconnect it an it comes out with the dash the steering wheel u need a t-30 torque tool an a philips, an a 18 mm socket its kinda hard to do by yourself so have someone hold the wheel while u take it off. hope this helped. it took me an my friend about 3 hours of work to swap out my interior from tan to black.. thats including the sunroof an carpet...
Old Mar 5, 2002 | 04:02 PM
J Gordon's Avatar
Default Re: Interior questions??? (thejdmkid)
On the bottom of the steering wheel there is a cover plate, take that off and disconnect the airbag module. If you have a 94'-95, you'll also have to insert the "shorting connector," stored on the inside of the cover plate, into the airbag module connector. If you have a 96' or newer, it automatically shorts when you remove the connector.
LoneAutosport
27
Jan 16, 2023 11:59 PM
StraightCivic
Mar 6, 2005 07:32 PM
Jdm93civic
Jan 8, 2005 09:05 AM
InfamousRS
Mar 4, 2002 10:24 PM
