engine problems
Old Nov 8, 2002 | 02:40 PM
Spudddy's Avatar
Default engine problems
Alright to start this is a 97 gsr w/ t3/t4 turbo ect. its having some minor problems after replacing the head gasket only ONE of the cylenders is firing, number one is the only one running. We've checked every sensor the injectors the fuel line, pumps regulator vacum lines, replaced the spark plug wires with cran 11mm they go with the fireball ignition system and tried 2 new set of spark plugs but yet still no luck. any other ideas? thanks guys
Old Nov 8, 2002 | 02:45 PM
Spudddy's Avatar
Default Re: engine problems (Spudddy)
note: we have also tried switchign the injectors with the one that works to another one and it still fails when we pull the spark plug wire on the first cyln... also we switched the inject sensors/electronics to see if that made any difference but didn't the car dies when we pull the first spark wire.. they ALL do spark that has been tested.
Old Nov 8, 2002 | 02:56 PM
ragejed's Avatar
Did you check your codes?
Old Nov 8, 2002 | 02:59 PM
Spudddy's Avatar
Default Re: engine problems (ragejed)
I'll check the codes tomarrow, i remember one of the guys saying it just flashed once but other than that it completly blew past my mind but thats somthing i'll take a look at thanks.
also, timing isn't off we thought thats what the initial problem is but to our surprise and after adjusting it about 15 times we came to the conclusion that it wasn't that.
[Modified by Spudddy, 4:00 PM 11/8/2002]
Old Nov 8, 2002 | 08:51 PM
threatcon13's Avatar
New User
were all four cylinders firing before you changed the head gasket???
Old Nov 9, 2002 | 07:31 AM
JBONES's Avatar
did you install the dis, the correct way........it is idot proff.......im n ot calling you and idot........or maybe your igniter is shoot...or maybe your coil done.....check those.....sounds like and ignition problem..it has to be in your distributer...good luck man............
Old Nov 9, 2002 | 11:53 AM
Spudddy's Avatar
Default Re: engine problems (JBONES)
yes, all 4 were firing and the car sounded fine, this time its firing and sounds reallllly bad and back firing every now and then. we just ordered a new crane dis the old one was pretty beat up it looked like well we will know in a couple days when it gets here
Civic Hybrid
10
Aug 17, 2008 09:35 AM
A2gt35r
Sep 30, 2007 06:26 PM
skata89
May 21, 2006 03:32 PM
QTKEG6
Jun 23, 2002 10:14 PM
