doing timing belt
Old Mar 3, 2003 | 11:14 AM
SamC's Avatar
Default doing timing belt
Hey guys,
I'll need to replace my 97 RS timing belt soon. Here's a list of parts I'lll be ordering, am I missing anything?
Timing belt
AC belt
Alt belt
PS Belt
Water pump
do I need to replace any pulley?
Oh, the teg will be at 70k soon, I'll also be changing
Coolant,
fuel filter
cap and rotor
[Modified by SamC, 8:15 PM 3/3/2003]
Old Mar 3, 2003 | 11:18 AM
NeoGSR's Avatar
Default Re: doing timing belt (SamC)
valve cover gasket
cam and crank seals
tensioners and pulleys
case of beer
best to do these when you got everything apart....
[Modified by NeoGSR, 2:29 PM 3/3/2003]
Old Mar 3, 2003 | 11:23 AM
RacerMike's Avatar
I was about to tell you about an Emissions recall in which Honda agreed to replace most tune up parts for free and check the emissions system, but its only for cars with 75k-150k. You may want to keep that in mind tho for the next time you want to change plugs, cap, rotor and wires. They also threw in a free oil change.
http://www.4acura.com/service/updates/98-031.asp
Mike
Old Mar 3, 2003 | 06:22 PM
NeoGSR's Avatar
Default Re: doing timing belt (RacerMike)
wow, that'd been nice if it covered my car too....that's quite a savings....
Mike
Old Mar 3, 2003 | 09:05 PM
Dan GSR's Avatar
Default Re: doing timing belt (NeoGSR)
interesting....im gonna have to see if i can get these parts free
Old Mar 4, 2003 | 12:16 AM
miketegra's Avatar
Hey guys,
Timing belt
AC belt
Alt belt
PS Belt
Water pump
Coolant,
fuel filter
cap and rotor
Make sure the water pump comes with a new rubber seal and have some black RTV high temp gasket sealer for the valve cover gasket. I also recommend doing the timing belt tensioner. Mine was actually making a squeeling sound before I replaced it along with the water pump, belts, etc.
Also, inspect your crankshaft pulley for cracks. The pulley on my GSR had cracks so I replaced it. I also put on a new crankshaft pulley bolt.
Have fun !
some tips here: https://honda-tech.com/zerothread?id=421701
hometheaterman
Jun 4, 2010 11:17 AM
BlitzSix
Feb 16, 2009 02:47 PM
The-Kid
Feb 8, 2008 03:47 PM
Nosepicker
Jan 12, 2008 06:48 PM
Eluder200K
Jan 27, 2003 01:50 PM
