Trunk Squeaking
Old Mar 4, 2003 | 02:36 PM
p nut's Avatar
Default Trunk Squeaking
I had my stereo turned down today and noticed there was some sqeaking noise coming from the trunk. Everytime I went over a little bump, it would squeak. I'm thinking it might be the little rubber bushings. Anyone have a good idea on how to take care of this? I have a 95 coupe, BTW.
Old Mar 4, 2003 | 03:08 PM
King_j's Avatar
Default Re: Trunk Squeaking (con)
you can try those bushings but i also have heard of people using electrical tape around the metal latch, this should stop the noise.
Old Mar 4, 2003 | 03:23 PM
x00gsr's Avatar
Default Re: Trunk Squeaking (King_j)
sounds more like a suspension problem if it squeaks when you go over bumps.
Old Mar 4, 2003 | 05:54 PM
p nut's Avatar
Default Re: Trunk Squeaking (x00gsr)
Well, I had my friend lean back to try and pinpoint the sound, and he said it was coming from the hatch. Maybe I'll try the electrical tape. I'll let you know if it works out.
Old Mar 5, 2003 | 11:50 AM
SupaTegRS's Avatar
theres little rubber bushings at the back corners of the hatch....unscrew them just a little bit, and test to make sure the hatch still closes. Repeat as necessary till the hatch closes firmly. if the hatch doesn't close, you went too far....screw em back in a little bit.
That should fix it.
Old Mar 5, 2003 | 11:57 AM
94TealGSR's Avatar
Default Re: Trunk Squeaking (SupaTegRS)
That should fix it.
I did this about 2 years ago and it has fixed it perfectly. If your system is loud like mine, you'll want to unscrew them a bit too far and then close the trunk hard. (get in the habit of making sure it's closed properly every time) That way you it won't rattle even with the stereo turned up.
Old Mar 5, 2003 | 12:20 PM
wuhungsixxx's Avatar
New User
That should fix it.
i have done this both in my crx and teg...but my teg now has a new rattle
Old Mar 6, 2003 | 02:45 AM
cbaLoy's Avatar
New User
Default Re: Trunk Squeaking (wuhungsixxx)
do you have an ITR sway bar? i have the same damn noise also. Like when you back out of your driveway...when the tires hit the ground at an angle...you get a "thulump." If not then i guess its just me. I think its my sway bar...i dunno could be the hatch?
Old Mar 6, 2003 | 08:54 AM
MattG's Avatar
New User
Default Re: Trunk Squeaking (cbaLoy)
If you have adjustable endlinks (heim joints) they may be bad. I have a rattle that seems to come from the hatch but its the endlinks rattleing. It only happens over small bumps when a few mm's of slack is taken out of the endlink (basically pushed up and down rapidly with little actual travel.
Old Mar 7, 2003 | 12:28 PM
B18Redline's Avatar
It may be the trunk latch
Old Mar 7, 2003 | 01:06 PM
bri's Avatar
bri
That should fix it.
i can't get the bushings to move in or out, seems like they just turn in place. aren't they fixed?
Old Mar 7, 2003 | 01:16 PM
LostGsr's Avatar
Default Re: Trunk Squeaking (bri)
Try to unscrew them a little in a counter clockwise rotation. Do all four of them and you should notice it will get harder to close the trunk completely.
anstitute
Suspension & Brakes
32
May 21, 2012 12:36 PM
xpsonic
Sep 10, 2004 04:54 AM
frost_0ne
Apr 14, 2004 09:02 AM
tylerdurden
Oct 27, 2002 06:00 PM
Balls
Jan 28, 2002 06:21 PM
