k&n drop in filter
Old Mar 5, 2003 | 10:17 AM
dip-set's Avatar
Default k&n drop in filter
is it better used in the stock air box or used out the air box like a regular intake...?
Old Mar 5, 2003 | 10:20 AM
VTECorona's Avatar
Default Re: k&n drop in filter (teg-your-it)
Are you talking about the box that the factory filter is enclosed in?
If yes, then keeping it enclosed will probably get you colder air, if you leave the cover off then you are sucking in engine compartment air which is similar to that of a non-cai intake. Warm air.
Old Mar 5, 2003 | 10:53 AM
ph0en1x's Avatar
Default Re: k&n drop in filter (97RedTegGSR)
I use it covered it makes a difference. If you have the filter exposed you will suck in hot air. With it covered you have a cai. That is how mine is set up. Just remove the resonator.
odiumred
Jun 22, 2007 11:27 AM
MCHAccordLX
Nov 12, 2006 04:37 AM
**DOHC HaTcH**
Feb 14, 2006 06:56 AM
suzuki515
19
Dec 17, 2005 05:32 PM
Iomega01
Aug 9, 2005 12:51 PM
