Help with Rusty Bolt
Old Mar 3, 2003 | 05:23 PM
Adachi's Avatar
Default Help with Rusty Bolt
I cannot get this one bolt off.. It is VERY VERY rusted. I tried WD40 and a super long bar for leverage.. and still nothing. Does anyone know a good rust remover I can buy? Something that will be able to eat through the rust in the threads in the bolt? WD40 isn't working at all. I'm going to need some aircraft quality stuff for this.. damn rust!
Old Mar 3, 2003 | 05:37 PM
KOALA YUMMIES's Avatar
Default Re: Help with Rusty Bolt (Adachi)
Use a penetrating lube and leave it overnight. Or use an impact wrench which it sounds like you dont have.
Old Mar 3, 2003 | 05:39 PM
Adachi's Avatar
Default Re: Help with Rusty Bolt (KOALA YUMMIES)
I can't get any power tools in there
Do you know any good penetrating lubes (besides WD40)?
Thanks
Old Mar 3, 2003 | 05:57 PM
tC_Dragon's Avatar
i had a hard time gettin off one of my caliper bolts last month... i even cracked a socket! what i did was buy a 1/2" drive ratchet and socket and it helped ALOT!!! it allows u to apply more pressure on it. Try that. And oh i soaked the bolt in pbblaster before i went at it.
Old Mar 3, 2003 | 06:00 PM
Eva01's Avatar
This is what I would suggest. Also find a longer bar! I use the bar from my floor jack and there is almost no bolt I can't break loose with that sucka. Just make sure you have a six point socket so you don't strip the bolt and have at it.
Edit: I typos!
[Modified by Eva01, 10:01 PM 3/3/2003]
Old Mar 3, 2003 | 06:38 PM
Rtzx9r's Avatar
GDD 1%
Default Re: Help with Rusty Bolt (Eva01)
"PB Blaster" is BY FAR the best stuff for this. (comes in spray can)
But if you tried all that, go to sears and they sell a Mapp Gas torch kit- the torch is on a long hose, and you can get it into anywhere you need. HEat the metal AROUND the bolt (not the bolt) and then try...
You will expand the metal around the bolt and it will make the bolt easier to get out. The torch is like 30 bux, but well worth it. (use it for exhaust jobs, lighting fireworks, etc)
Old Mar 3, 2003 | 08:04 PM
Adachi's Avatar
Default Re: Help with Rusty Bolt (Rtzx9r)
Great advice! Thanks! I haven't tried PB blaster yet, so I'll try that first.
**EDIT**
DAMN! I looked up a picture of Pb blaster.. and I saw it at Autozone today, but I din'dt know if it was any good so I put it back and bought this other one called "Rust begone" or something.. damn.. owell, back to autozone I guess.
[Modified by Adachi, 9:10 PM 3/3/2003]
stevevang
Mar 27, 2016 04:46 AM
higgunscrx
Welding / Fabrication
May 1, 2007 08:57 PM
a1320addict
Aug 26, 2006 05:19 PM
ungcobob
Jul 16, 2006 10:56 PM
reed857
10
Jun 7, 2006 06:20 AM
