Engine won't start, Need help
Old Oct 22, 2004 | 05:05 PM
ton_gu's Avatar
Default Engine won't start, Need help willing to pay
Vehicle is 93 integra GS. Replaced spark plugs with new ones. Engine won't start. Replaced distributor with a 94 distributor. Able to drive car home. Now car won't start. No engine light is on, I do smell fuel, the start cranks, battery not low, I do get sparks, oil light does go off. No vaccum leaks, all the grounds are clean. Is it my ignition timing or not enough air?
Need help. willing to pay if someone can fix it. Located in the bay area.
Old Oct 22, 2004 | 07:56 PM
Keno20's Avatar
Default Re: Engine won't start, Need help willing to pay (ton_gu)
sounds like timing to me but not 100%. have u tried push starting it or anything?
Old Oct 23, 2004 | 05:34 PM
ton_gu's Avatar
I tried push starting the car but no luck. Been raining lately so no chance to tow it to the shops. Local shops offer to fix the problem for $800. They don't even know what wrong.
Old Oct 24, 2004 | 03:42 PM
Keno20's Avatar
Are you saying that your car wouldnt start, then you put the 94 dizzy on and it started then drove home, and now wont start at all? If this is the case then there must be some kind of correlation with the dizzy. Maybe the crank angle? or bearings in the dizzy could be seized?
Old Oct 24, 2004 | 03:43 PM
Keno20's Avatar
Default Re: Engine won't start, Need help willing to pay (Keno20)
If you wanna check out the dizzy, take the cap off and you should be able to turn it freely, if not it's most likely seized the whole shaft.
Old Oct 24, 2004 | 08:01 PM
b16a2delsol's Avatar
mine had the same problem.... it ended up being a cracked head/ blown head-gasket..... hopefully yours does not have the same problem...
Old Oct 24, 2004 | 09:42 PM
Obie_Ricee's Avatar
plug in your ecu and check the engine light signals to tell whats wrong. if you need to find the ECU plug its under the dash and heres where you can find codes.http://www.integra.orcon.net.nz/ecucodes
Old Oct 24, 2004 | 10:05 PM
drussell4801's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keno20 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe the crank angle? </TD></TR></TABLE>
mariposa921
Honda CR-V & Element
Sep 18, 2012 04:31 PM
BAY_99DB8LUV
Apr 2, 2011 07:54 PM
DA9integra93
Mar 26, 2008 04:57 PM
allmotorej8
Oct 5, 2004 12:45 PM
DSC
Mar 31, 2002 08:05 AM
