master cylinder differences
Old Oct 26, 2004 | 06:09 AM
mdhimes's Avatar
Default master cylinder differences
Alright boys. I have searched all over the place and I can't come up with anything. Is there any difference between 3rd gen integra master cylinders
46100-ST7-A52 ('94-97)
46100-ST7-L51 ('98-01)
Booster assemblies?
46400-SM4-951 '94-97)
46400-S84-E01 ('98-01)
The earlier ones are more expensive for some reason. Both cylinders are 1". Both boosters appear to be the same size as well. However you can not interchange the cylinders with the boosters because of the mounting pattern on the cylinders, angled vs horizontal. The later cylinder and booster was used with the type r which had slightly larger brakes so that could be a plus I suppose.
Below is a link to a picture of them both. The 98 and up cylinder is on the right while the booster is only representative of the earlier model.
http://www.acuraparts247.com/s...ch=no
By the way, the info above is from http://www.acuraparts247.com
Thanks, any info will be appreciated.
Old Oct 27, 2004 | 09:29 PM
mdhimes's Avatar
Default Re: master cylinder differences (mdhimes)
no one here knows????
Old Oct 27, 2004 | 10:05 PM
NXSpoon's Avatar
ABS and Non-ABS ??
Old Oct 27, 2004 | 11:36 PM
Bay_707's Avatar
94 - 01 all had abs on the gsr's
Old Oct 28, 2004 | 02:55 AM
HONDA RR's Avatar
Default Re: (Bay_707)
will a 2001 brake master off of a type r fit a 2001 gsr?
Old Oct 28, 2004 | 02:56 AM
HONDA RR's Avatar
Default Re: (MITSUBA)
i meant the brake master cylinder.
Old Oct 28, 2004 | 03:23 PM
mdhimes's Avatar
Yeah the type r MC and booster are the same as gsr/ls as long as they are '98+. As per the information off of website I mentioned in my original post the part numbers are the same. Perhaps the difference in the braking systems between type r and gsr/ls is in the proportioning which I assume happens in the ABS module. So there really is no difference in the master cylinders or boosters, just a bit larger dia' rotors.
Apr 5, 2018 11:34 AM
Big Daddy Go Fast
Oct 17, 2006 11:39 AM
fastcivicboy
Apr 27, 2005 11:21 AM
