To add a Crank sensor, do I have to Change the oil pump?
I am converting my OBD1 B18B1 to OBD2.Do I have to change the oil pump in order to add the crank sensor?
Re: To add a Crank sensor, do I have to Change the oil pump? (RippleSound)
yes you do. you will need the gear, the sensor, the oil pump, and the lower timing belt cover.
Re: To add a Crank sensor, do I have to Change the oil pump? (turbodegsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodegsi »</TD></TR><TR><TD CLASS="quote">yes you do. you will need the gear, the sensor, the oil pump, and the lower timing belt cover. </TD></TR></TABLE>
most complete answer. also, you will need the bolts to mount the sensor to the oil pump. that should do it.
yup i had to do this to my DM f20b in my prelude. it was the same thing
oilpump, gear, sensor, and timing cover, or ust notch your OEM one.
if you do not have the gear, the car will not start, it might start like once every 10 starts.
