Idle is fluctuating need help?!
Old May 30, 2006 | 03:32 PM
VTECth1s's Avatar
Default Idle is fluctuating need help?!
I have an LS/VTEC in my dc2, few minutes ago, i started up the car after i went to bank, car was already warmed up and everything and, once it started up the idle drop down to like 200 or 300 rpm, like it was gonna die, then it was bouncing up and down from 200- 1000rpm, for couple secs, then car just turned off, started up the car, then did it again slighty but put some gas, then it was fine. Its not idling like that right now, but i kno it'll happen again, could i possibly have bad spark plugs?, or what could it be?. Thanks!
Old May 30, 2006 | 04:49 PM
tegG2's Avatar
Default Re: Idle is fluctuating need help?! (egg6vtak)
Could be plugs, but may be IACV or MAP.
Old May 30, 2006 | 04:53 PM
VTECth1s's Avatar
Default Re: Idle is fluctuating need help?! (tegG2)
clueless bout what the IACV or MAP is, friend told me might be the cap, rotor and coils?
Old May 30, 2006 | 06:03 PM
dcRay's Avatar
iacv and map sensor have the same type of plug. Often times, people switched them by mistake and the car will symptoms like you.
Old May 31, 2006 | 05:26 AM
VTECth1s's Avatar
Default Re: Idle is fluctuating need help?! (dcRay)
hmm, ill have that checked out!, thanks anything else could it possibly be?
JDM-KIDD
Feb 5, 2011 01:04 PM
IVI
May 24, 2005 03:47 AM
92eg6lsvtec
Sep 19, 2004 08:19 PM
IVI
27
Aug 29, 2004 09:27 PM
RnR Racing
Apr 8, 2003 11:15 AM
