quick questions....
Old Dec 9, 2008 | 09:55 PM
itzyaboyzeem03's Avatar
Icon2 quick questions....
i have a b18b1 in my hatch, and lately my temp gauge would stay on cold, even when i run it hard...i stay in houston tx, and the weather has been around the 60's lately, does this mean my thermostat is gone??? and another question...on cold starts my car would idle down to zero almost cuttin off but then idling back up to like 300 before going back down to zero, it would do this for a good 5 mins or so....any suggestions on what to check???
Old Dec 9, 2008 | 10:25 PM
SOHC_4dr's Avatar
your thermostat doesn't just dissapear. it may be stuck open. and as for the idle it cant be 300, it couldnt run. to often people overlook the very tiny hash mark(500) before the bigger hash mark(zero). your idle issue could also be related to the cooling issue. when your low on coolant it can affect the idle because of the FITV. if your thermostat is stuck open then its allowing more coolant to pass than normal and not enough is reaching the FITV. are your fans running constantly, like at start up?
Old Dec 9, 2008 | 10:37 PM
i actually meant 500 not 300.....and the main fan on the left of the car is always on when the car is on......
Old Dec 10, 2008 | 09:25 PM
SOHC_4dr's Avatar
thats one issue. find out why its on. i dont know where to go from there lol
Old Dec 10, 2008 | 09:36 PM
racebum's Avatar
go to a parts store and borrow the scan tool, watch the coolant temp on the screen. if it also reads low you have one of two things. a bad sensor or stuck thermostat. even with the stat wide open the car should reach 150ish, if the scan tool shows 140-160 after driving to the store and getting as hot as you can get it you have a thermostat problem. if the scan tool shows something wacko like 73deg after driving there your sensor needs to be replaced.
Old Dec 10, 2008 | 09:51 PM
ok ill look into that....also lately when i step on the gas it takes about a second or two before the car actually revs up, like if its laggin or something, this only happens when i first start up....but after i let the car run for a while then this will go away...is this a throttle problem??
Old Dec 11, 2008 | 06:44 PM
Or is it a fuel problem?
Old Dec 11, 2008 | 08:24 PM
SOHC_4dr's Avatar
prolly a clogged fuel filter. that is common when its clogged. has it been changed?
Old Dec 12, 2008 | 01:27 PM
i actually changed the fuel filter about 2 months ago
gian_ed7b16a1
21
Feb 12, 2016 08:40 PM
AReynolds91
Mar 14, 2012 03:59 PM
e30FTMFW
Nov 18, 2008 11:52 AM
dc4drewH
Aug 31, 2005 02:00 PM
ThisLittleSleepeR
Apr 6, 2005 09:35 PM
