clutch conversion
Old Dec 11, 2008 | 02:44 PM
eastbayg's Avatar
Default clutch conversion
i have a 93 Da integra with a cable clutch. i also have a 98 gsr transmission that takes a hydro clutch. does anyone know how to convert so itll fit my car?
Old Dec 11, 2008 | 02:47 PM
Jas9848's Avatar
you need a flywheel, clutch for a hydro trans, trans mount for manual hydro, master cylinder, slave cylinder, clutch lines, pedal assembly, manual ecu, maybe a few little things im forgetting but it involves some work, time and money, but doable
Old Dec 11, 2008 | 04:55 PM
1SicLS's Avatar
wow! or just by the conversion kit and keep your flywheel and get a new clutch.
i think hasport makes cable to hydro conversion
Old Dec 11, 2008 | 07:27 PM
tilegend's Avatar
he's going to have a hell of a time trying to mount a clutch master cylinder... its been done before but consider that its a total hack job.
either hasport or innovative makes cable/hydro conversion kits
add a hydro tranny mount...
and you're good to go...
no need for a flywheel (maybe a resurface) all b-series are the same
clutch will also be the same (92+ integras use the big input shaft)
and considering he already has a manual car... i see no need for a MT ECU or the pedal assembly.
Convert
Feb 1, 2009 09:51 PM
brian g
Mar 31, 2008 08:17 AM
1990hf
Jul 20, 2004 03:02 PM
tgreaves
Nov 17, 2003 12:30 PM
