Transaxle???
Old Dec 5, 2008 | 10:39 AM
smittysbmx@aol.com's Avatar
Default Transaxle???
what is the best way to fill my transaxle??? is there a different way than the level check plug?
Old Dec 5, 2008 | 10:42 AM
there is what appears to be a breather tube on top of the transaxle....could you possibly put the fluid in there? or does anyone know what that is?
Old Dec 5, 2008 | 10:59 AM
TunerN00b's Avatar
Why would you need a different way?
$5 Pep Boys "fluid pump" with hose and 5 minutes of pumping = full transaxle
Sijray21's Avatar
there's a gear connected to the speedo on the top of the tranny - that'll be your best bet -- you'll need a long hose/funnel to fill it from the engine bay
it's held on with a couple 10mm bolts and goes right into the transaxle
the idea for the pump and the filler bolt is the best idea to get the proper amount of fluid though
Old Dec 5, 2008 | 11:05 AM
ok thanks! anyone know what the little steel tube coming off the top of the transmission is?
ChilBlu92
Aug 10, 2009 05:49 PM
Mr. Lucky
Honda S2000
Mar 15, 2006 10:06 AM
imadigitalgod
Oct 22, 2004 08:33 AM
Floyd
May 9, 2002 10:58 AM
slash00R
Mar 24, 2002 10:35 AM
