a/c compressor problem help
Old Dec 6, 2008 | 09:18 PM
thunderboy's Avatar
Default a/c compressor problem help
Rear noise outo my a/c compressor now my a/c don't work what can be the problem?? help please
Old Dec 6, 2008 | 10:51 PM
SOHC_4dr's Avatar
it may have siezed up. check belt tension, wiring/fuses, and if they are ok you'll need a new compressor.
Old Dec 7, 2008 | 06:03 AM
jayare05's Avatar
x2.. typically when an a/c compressor is on its way to siezing up.. they will make a noise everytime it kicks on.. try turning it by hand.. if you feel some restriction or its not turning smoothly.. its on its way
Old Dec 7, 2008 | 11:56 AM
b18c1ej8's Avatar
i have a full ac system for a dc integra if you need
Old Dec 7, 2008 | 06:15 PM
SOHC_4dr's Avatar
that will only test the pully, not the piston inside the comp. you'll need the clutch to be engaged to feel the restriction.
Adankid
Jun 16, 2009 03:12 PM
civicstar
Aug 29, 2007 07:17 AM
EKidd
Jun 16, 2007 06:02 PM
noworldorder
Mar 1, 2005 06:22 PM
