lowering my DA problem!!!
Old Sep 23, 2010 | 09:15 PM
mapa1229's Avatar
Default lowering my DA problem!!!
i lowered my Da9 a while ago on stock struts and stock camber arms, with coilovers... i then got some aftermarket camber arms, and my car isnt as low, but for some reason my car is still getting camber, any ideas?
any suggestions of what brand camber arms i can buy that work good?
also will blown struts make the car have more camber?
Old Sep 24, 2010 | 05:44 AM
Gekko's Avatar
Default Re: lowering my DA problem!!!
A camber kit will only give you so much adjustment. If you are pretty low then you still won't be able to get your camber back to stock spec.
I'm lowering my DA as we speak and I'm not planning on getting about a camber kit, check out this thread: https://honda-tech.com/forums/suspension-brakes-54/no-you-do-not-need-camber-kits-2614449/
On stock a-arms, the only thing that will change your camber is your ride height. Since springs and not struts determine your ride height then blown struts will not change your camber.
You'll probably get better responses posting a question like this in the Suspension section.
ware
Suspension & Brakes
12
Feb 15, 2007 05:50 PM
pcorad
Dec 1, 2002 06:18 PM
Wai
Jan 2, 2002 09:08 AM
Edwin
Aug 20, 2001 07:52 PM
Chip398193
Jul 29, 2001 11:38 AM
