Will this setup work? What else will I need? Help!
Old Apr 2, 2003 | 10:38 AM
G a b e's Avatar
Banned
Default Will this setup work? What else will I need? Help!
Sorry in advance for the n00b question...
I have a JDM b18c. I would like to run USDM b16a overbore pistons, and a Mugen head gasket. According the the compression ratio calculator at c-speedracing.com my compression would be at about 11.68663275993971:1. I also have a chipped ECU. I have heard I should go down to a colder spark plug. yay, nay? Will I need to invest in an FPR? This car is not a daily driver, but it defineately does get driven a lot, and reliability is a big factor.
Also, I currently have 00 spec ITR cams. If I get ITR outter valve springs, how high would you say I could safely raise the redline, and at what point would the cams stop making power?
I am trying to avoid dynoing my car at this stage, as I will be quite broke, and I don't consider this to be the finished product.
[Modified by G a b e, 4:48 PM 4/2/2003]
Old Apr 2, 2003 | 12:53 PM
95 integra's Avatar
Default Re: Will this setup work? What else will I need? Help! (G a b e)
you might want to run a colder plug, but I strongly suggest that you retard timing a couple degrees and that you always run 93(or highest) octane gas. BTW, are you sure your valves wont hit the piston when VTEC engages? BTW, you know with the mugen head gasket(single layer I assume?) that you will need cam gears to correct timing right? Redline is going to depend mainly on your valve springs.
Old Apr 2, 2003 | 01:00 PM
JeremyL's Avatar
Default Re: Will this setup work? What else will I need? Help! (95 integra)
wait til u have the money and get it all built and tuned right
cheap, reliable, fast - pick only two
Old Apr 2, 2003 | 08:37 PM
G a b e's Avatar
Banned
No I did not know that... And isn't the Mugen a 2 layer?
Which I said I would have ITR...
I will get it dynoed eventually, but I don't have the money to drop right now, and this is not my final setup. I need something to drive at the moment.
[Modified by G a b e, 3:01 AM 4/3/2003]
Old Apr 2, 2003 | 10:38 PM
seanb18c1's Avatar
I doubt you'll need a colder plug. I'd also advise going against an off the shelf ECU. Do a hondata, in the long run, it'll be more woth it. Do you have the kenji chipped ECU?
Old Apr 2, 2003 | 11:06 PM
G a b e's Avatar
Banned
Default Re: Will this setup work? What else will I need? Help! (seanb18c1)
Hondata is on the way, as soon as I can afford it. I got the ECU chipped before I was planning on doing all of this stuff. I do not have a Kenji chip, but I would like to get my hands on one. Currently I have a custom J's racing, and a Mugen chip.
Old Apr 3, 2003 | 08:00 AM
95 integra's Avatar
If you have a 2 layer head gasket it timing shouldnt be a big deal, but yes since shaving the head(or using a thinner head gasket) changes the length bewteen the cam gear and the crank pulley it changes your cam timing by a few degrees, but honestly with a 2 layer gasket it probably wont change it enough to worry about, but if your going all motor you're probably going to want to "tune" your timing as well.
namniki
Aug 7, 2015 07:11 AM
yoorang
18
Nov 12, 2006 01:29 PM
jaydem_ekizzle
May 7, 2006 02:02 PM
smkngsr
Apr 28, 2005 12:28 PM
Liquidx02
Feb 22, 2002 09:42 AM
