Boost Gauge help!!!
Old Apr 4, 2003 | 05:03 PM
BlackB18CTeg's Avatar
Default Boost Gauge help!!!
I installed my boost gauge, its an autometer 35 psi boost gauge and doesnt have vacuum on it, the lowest it goes is 0. Anyway, I dont have a turbo, but I have one coming in, I installed the boost gauge early, well anyway what I am getting at is that hte needel doesnt move AT ALL!! is this normal? I know that I am not boosting, but I would expect a little movement. THank you.
Old Nov 3, 2003 | 07:13 PM
torq2k's Avatar
Default Re: Boost Gauge help!!! (BlackB18CTeg)
It wont move unless there is either some boost or vacume going on. Right now its just looking pretty
Old Nov 3, 2003 | 07:20 PM
maxxdout's Avatar
where do you have the gauge hooked up to. If you wanted to measure manifold vacuum you could take your manifold. You should see a difference at idle and then at different throttle levels....if you care that much. Or just leave it alone until you actually need it.
Old Nov 3, 2003 | 08:36 PM
turbo craig's Avatar
Default Re: Boost Gauge help!!! (maxxdout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxxdout &raquo;</TD></TR><TR><TD CLASS="quote">where do you have the gauge hooked up to. If you wanted to measure manifold vacuum you could take your manifold. You should see a difference at idle and then at different throttle levels....if you care that much. Or just leave it alone until you actually need it.</TD></TR></TABLE>
the guage he has doesnt read vacume....i think u should get a new guage which shows both boost and vacume...and u wont see any movement in the needle bc if ure car doesnt have a turbo or sc u wont see any boost and the guage wont read anything above 0 ever
Old Nov 4, 2003 | 03:07 PM
2000Si47203's Avatar
Hey blackb18cteg, where is my turbo timer that I paid for on the 19th?
Old Nov 4, 2003 | 04:27 PM
Default Re: Boost Gauge help!!! (2000Si47203)
https://honda-tech.com/zerothread?id=649964
vladd
Nov 23, 2006 05:46 PM
R6E6I6D
Nov 24, 2005 04:36 PM
vangc6780
Apr 26, 2005 10:10 PM
metal-x
Nov 22, 2002 08:30 AM
CalvitoSol
Jun 13, 2002 05:02 PM
