Tranny problems!
Old Mar 18, 2004 | 06:28 AM
Miss PSI's Avatar
Default Tranny problems!
I have a 95 LS with 156k
I just replaced my driver side axle last night...since I heard a popping noise whenever I let off the throttle or went around a turn..I test drove the car last night and it was fine...
This morning on my way to work all of a sudden I lost all power to my wheels in 5th gear, I tried every other gear, but still no power to the wheels. When I finally stop the car, I try reverse...no luck. So, I jack the car up and its leaking gear oil. What is everyone's ideas?
I am towing the car tonight afterwork to take a better look. The car only drove for about 15 min total after the axle change.
Old Mar 18, 2004 | 07:04 AM
.M.'s Avatar
.M.
Default Re: Tranny problems! (Bitchinteg)
cv joint + crack tranny?
Old Mar 18, 2004 | 07:07 AM
sudds's Avatar
sounds like the axle came out, but i could be wrong. it happened to me once.
Old Mar 18, 2004 | 07:16 AM
Dan GSR's Avatar
Default Re: (sudds)
man i just had this happen to someone,
and i diagnosed it as a hole in the clutch side of the case
sadly i was right
but fortunatly i was able to fix it, and weld up the hole
Old Mar 18, 2004 | 08:53 AM
Miss PSI's Avatar
ok, it shouldn't be just an axle coming out...what would explain the gear oil...
I hope its not a hole/crack in the case....it might be...
I'll fill everyone in after we inspect her tonight
Old Mar 18, 2004 | 09:39 AM
Ron Carroll's Avatar
Default Re: (Bitchinteg)
If the axle was not popped all of the way in it can pop out and cause what you are discribing, jack the car up and look at the inner joint if it is out at all just pop it in all of the way, you should not be able to pull it back out, if you can the litlle spring clip on the inner joint may be bad and will need to be replaced. When the inner c/v joint popps out of the trans it will leak gear oil.
Old Mar 18, 2004 | 10:04 AM
FastSS's Avatar
Yea I hope its not a hole in your case also, although we should have a fresh tranny chillin around TFGG somewhere
Hopefully your axle just kinda popped out a little or you grenaded another axle...
or wait, the passenger side axle is mine... NOOOO dont grenade that one =P
Its all gravy, will get you at 4 and we can go have a look
Old Mar 18, 2004 | 06:20 PM
FastSS's Avatar
Default Re: (FastSS)
yup... for some reason the passenger axle decided it didnt want to live in the tranny anymore... so it popped out enough to dissengage it from the diff and spray tranny fluid everywhere
vanmaster420
Mar 4, 2007 09:29 PM
dthug
Feb 14, 2007 03:43 PM
t0ekn3e
23
May 15, 2005 06:44 PM
riceisnicenv
Oct 13, 2004 11:34 AM
1hotintegra
Oct 14, 2002 11:26 PM
