Specific Power Window Questions: Need Help PLEASE.
Old Mar 20, 2004 | 02:59 PM
JL 74's Avatar
Default Specific Power Window Questions: Need Help PLEASE.
I posted this in another thread but have additional Q's.
1. I thought my motor was bad, so I got another motor.
When I connected the wires to the new motor(not attached to the window yet), it spun for a while then it stopped. Does this mean it is my switch that has the problem, and not the original motor?
Note: The passenger side works (not the driver) and since they lead to the same wire, I assumed the control switches are okay. Was that a bad assumption?
The fuses are okay, btw.
2. If I need to replace the motor, I need to remove four bolts. Will the window "drop" and break once I remove all four bolts? Should I have someone hold on the glass?
3. If anyone has a nice procedure to replace the PW motor, I can really use it. I searched but no luck. I'll try again, maybe in non-Integra forum.
Thanks. It is a 98GSR btw.
Old Mar 20, 2004 | 03:46 PM
SuzukaBlueAP2's Avatar
Default Re: Specific Power Window Questions: Need Help PLEASE. (JL 74)
do you have any kind of manual for your car ? Haynes ? Helms ? Chiltons ?
They will have a detailed process of taking the motor out. I replaced the regulator in my 98 Teg before. No, the window won't just fall and break. atleast mine didn't.
I know you said your fuses were ok, but isn't there a relay under the hood for that as well? Maybe could be that.
You said the pass. side works, can you put the pass. window down from the driver's switch ?
Also, if you could get +12volts to the window motor itself, that would also give you and idea if it is the motor or something else, such as wiring or relay.
Old Mar 20, 2004 | 03:56 PM
91jteg's Avatar
you need the glass on the track when you plug the motor in there is a positioning sensor that tells the motor when to stop
Old Mar 20, 2004 | 05:34 PM
JL 74's Avatar
Default Re: Specific Power Window Questions: Need Help PLEASE. (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">do you have any kind of manual for your car ? Haynes ? Helms ? Chiltons ?
.</TD></TR></TABLE>
I have a Haynes but the instructions are so vague, and since I am not really "handy", I need a more detailed one like Helms.
I guess if I can't find the answer here, I'll buy a Helms.
Old Mar 20, 2004 | 10:05 PM
Default Re: Specific Power Window Questions: Need Help PLEASE. (91jteg)
wrong. there is no such sensor. I have had my motor.regulators out before, and hooked them up to a direct power source. The regulator only extends so far. That's how the window "knows" when to stop going up.
I have the helms on my computer...i'll see if i can't copy and paste on here what you need.
Old Mar 20, 2004 | 10:25 PM
Hope these help!!
Old Mar 21, 2004 | 01:04 AM
Seedc2's Avatar
if you are tight on money but want a helms try searching for the link to download the 94 integra helms in pdf format.
Old Mar 21, 2004 | 11:49 AM
JL 74's Avatar
Thanks. That really helps a lot.
87 SiviK Si
Mar 16, 2011 05:06 PM
streetlights
Dec 5, 2008 10:06 AM
streetlights
May 22, 2008 09:07 AM
spinez
Mar 20, 2005 11:03 AM
JL 74
May 21, 2004 01:09 PM
