Oil filter
Old Mar 18, 2004 | 10:55 AM
wup69's Avatar
Default Oil filter
Any suggestions for a good oil filter for a 98 GSR (65k)...im going to mob 1 synthetic, and im between K&N, Mob 1 filter, Fram and AC delco
Old Mar 18, 2004 | 10:56 AM
Audi A4's Avatar
Default Re: Oil filter (wup69)
umm oem honda is ur best bet
Old Mar 18, 2004 | 11:00 AM
quikB18B's Avatar
Default Re: Oil filter (DRAG lll INTEGRA)
Well honda changed to the smaller filter(to increase oil pressure) a few months ago,plus I think thier new ones are made by Fram. I used to run nothing but Oem filters, but now I run Bosch filters(made by filtech) who used to make the Oem honda ones.
You could use the s2k filter, (only one that didn't change but dealers want a grip for those. Mine wante $10.99
do anarchived search on oil filter, and you should find plenty of threads made when honda changed thier filters.
Old Mar 18, 2004 | 11:01 AM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG lll INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">umm oem honda is ur best bet </TD></TR></TABLE>
Not anymore. USDM oil filters used to be USA made Filtechs. While Japanese filters wer made by Toyo Roki. Now, all of the USDM filters are made by Fram. I'm not a big fan of Fram because of their cardboard endcaps and spotty construction.
Some good filters are made by Champion Labs (K&N, Mobil 1,Bosch, AC Delco and Supertech). Also, Wix (Napa Gold) makes some good filters.
Old Mar 18, 2004 | 11:22 AM
advanracing62's Avatar
Default Re: Oil filter (timmy8151)
holy carp! didn't know OEM Honda filters were now Fram----
Old Mar 18, 2004 | 02:11 PM
ThePro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">
Not anymore. USDM oil filters used to be USA made Filtechs. While Japanese filters wer made by Toyo Roki. Now, all of the USDM filters are made by Fram. </TD></TR></TABLE>
Fram
I once saw a website about the difference between the old OEM Honda and the JDM OEM Honda filters.
The JDM ones were the shizz! They had more oil holes and more filter media and just plain better. Seems the JDM people keep everything good for themselves. We need to all pool our money and move to JDM land.
Old Mar 18, 2004 | 02:32 PM
Default Re: Oil filter (ThePro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThePro &raquo;</TD></TR><TR><TD CLASS="quote">
We need to all pool our money and move to JDM land.</TD></TR></TABLE>
except the JDM wants to be USDM... then we'd have to convert back to USDM cars and be the super mack pimp daddies..
Old Mar 18, 2004 | 04:08 PM
RedGSR's Avatar
The new Honda oil filter (smaller one) are made by Honeywell. These new filters are even worse than the old Fram filter.
Honeywell makes good air filter, but not oil filter
Old Mar 18, 2004 | 04:10 PM
ekb18cCivic's Avatar
Default Re: (RedGSR)
i'd go with the mobil 1 filter all the way! .. they have a very good quality filter .. unlike most compnies cheap cardboard crap.. I.E FRAM
Old Mar 18, 2004 | 04:12 PM
svtec's Avatar
L D E S
Default Re: Oil filter (advanracing62)
fram is ghey.
i quit using honda oem when i found this out.
k&n is pretty good.
Old Mar 18, 2004 | 04:27 PM
projectTeG's Avatar
fram does it for me
Old Mar 18, 2004 | 04:42 PM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedGSR &raquo;</TD></TR><TR><TD CLASS="quote">The new Honda oil filter (smaller one) are made by Honeywell. These new filters are even worse than the old Fram filter.
Honeywell makes good air filter, but not oil filter </TD></TR></TABLE>
Honeywell owns Fram, so you're still getting a Fram filter.
Old Mar 18, 2004 | 05:32 PM
londa hover's Avatar
Default Re: (timmy8151)
amsoil is the best. and moble1 and k&N take 2nd
go to amsoil.com they got some tests to prove they make the best synthetic oil and oil filters
Old Mar 18, 2004 | 06:44 PM
Chris1091's Avatar
Default Re: (londa hover)
Use OEM Honda or Bosch.
Old Mar 18, 2004 | 06:52 PM
cougar10ag's Avatar
crap i forget the page where they took apart all the filters and rated them. i forget what was number one. but mobile 1 i think rated very high
Old Mar 18, 2004 | 06:55 PM
Kendall's Avatar
I believe the Mobil 1 filter is identical to the STP filter in every way. The only difference is the bling factor you get for using a Mobil 1 filter.
-Kendall, who is all about the Mobil 1 bling.
Old Mar 18, 2004 | 07:05 PM
cougar10ag's Avatar
YAHTZEE!
http://www.overboost.com/story.asp?id=1143
so the STP S2903 is ranked the best... thin case mind you so if you expect rocks and **** hitting the filter choose somehting wiht a thicker case
Old Mar 18, 2004 | 07:13 PM
RayB's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">I believe the Mobil 1 filter is identical to the STP filter in every way. The only difference is the bling factor you get for using a Mobil 1 filter.
-Kendall, who is all about the Mobil 1 bling.</TD></TR></TABLE>
I think the only difference between the STP and the Mobil1 besides price is that the Mobil1 filter element has some kind of coating.
I remember reading an article some guy did a while back where he cut a bunch of oil filters for hondas open and showed the insides of them. If I remember correctly the Fram, Purolator, and US oem Honda were three of the worst constructed. They had poorly made and installed anti-drainback valves. They also had low quality filter elements in them. I wish I still knew where to find the link.
Old Mar 18, 2004 | 07:18 PM
cougar10ag's Avatar
mobile one has the highest cotton and polyester mix, and the best bypass valve. and it's the thickest.. if it was cheaper, like $3 i'm sure it would be number one.
this, to me, is made for good flow with reduced filtering so if your engine is always dirty or you do prolonged oil changes then i would shy away form this. but if you change your oil frequently and don't cre abotu the high price tag then this seems like the best. i think i'm gonna try the stp next time
R_ACE1
Jun 16, 2009 06:56 PM
Jewls
24
Jan 17, 2009 05:16 PM
redDAinteg
Sep 3, 2007 12:19 PM
SIMATIC
Oct 15, 2003 04:01 AM
