Low idle
Old Mar 17, 2004 | 06:55 PM
dannylDAsport's Avatar
Default Low idle
i searched and read about low idle in Ht, i got a 93 teg and recently installed a cheap intake, should i reset the ecu first or back out of the idle screw. which will be the best way to solve this problem?
Old Mar 17, 2004 | 06:57 PM
Kendall's Avatar
I would make sure that it's not something slightly clogging the air flow. Reinstall the stock airbox and see what that does. If it doesn't solve your problem, then check out the ECU and finally, adjust the idle manually.
Old Mar 17, 2004 | 07:04 PM
Default Re: (Kendall)
ok, i'll do it this weekend when i have time
Old Mar 18, 2004 | 07:07 PM
Default Re: Low idle (dannylDAsport)
im not sure about this, when i adjust idle, do i leave the car running?
Old Mar 18, 2004 | 07:29 PM
cougar10ag's Avatar
EDIT* whoops my bad about the idle speed without the IAC...
yes, i dunno about DA's but i'm guesing it's the same. warm up your engine, unplug your idle air control valve. if it's working properly the engine should drop in it's idle. if not then it's broken and you should replace it wiht a known working one. turn the idle screw so for a G3 it's at 480+/-50rpms then plug the IAC back in and it goes to 750.
Old Mar 19, 2004 | 10:04 PM
Default Re: (cougar10ag)
is the idle air control valve located on the intake hoseing that goes up to intake manifold??
Old Mar 23, 2004 | 09:14 PM
cougar10ag's Avatar
the IAC is on the side of the TB facing the firewall, right next to the TPS. the IAC plug is under the sensor.
Old Mar 28, 2004 | 10:41 PM
what is the proper way to adjust idle? stock air box didnt do anything i still get low idle. It sometimes goes to about 500 rpm and i feel car shaking.
Old Mar 28, 2004 | 11:38 PM
G1 TEGGY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannylDAsport &raquo;</TD></TR><TR><TD CLASS="quote">what is the proper way to adjust idle? stock air box didnt do anything i still get low idle. It sometimes goes to about 500 rpm and i feel car shaking. </TD></TR></TABLE>
Reset the ECU first, then leave the car running and loosen your idle screw by a 1/4 turn each time.. so:
1) Start car
2) Let warm up to normal temp
3) Check idle, if still low-
4) Turn idle screw 1/4 turn counter-clockwise
5) Wait 5 seconds
6) Refer to Step 3
Zee.I
Jul 11, 2021 11:36 PM
b20bFourDoorCivicLX
Honda CR-V & Element
Oct 10, 2013 06:35 PM
downshift3r
Sep 30, 2013 06:34 AM
BrokenRex
Oct 13, 2005 08:25 PM
91SE
Feb 18, 2003 04:35 PM
