engine mechanical problems?
Old Oct 7, 2005 | 08:22 PM
Steve-o's Avatar
Default engine mechanical problems?
has anyone ever had problems with crank, rods, pistons? or moters blowing up? with a stock ls (94)
Old Oct 7, 2005 | 08:37 PM
SuzukaBlueAP2's Avatar
Default Re: engine mechanical problems? (Steve-o)
To answer that question, Yes. People have had various mechanical failures for hundreds of different reasons.
Old Oct 7, 2005 | 08:43 PM
Steve-o's Avatar
Default Re: engine mechanical problems? (ScreaminTeg)
have you had a moter blow up?
Old Oct 7, 2005 | 08:52 PM
a few actually.
Old Oct 7, 2005 | 08:58 PM
Steve-o's Avatar
what caused it?
Old Oct 7, 2005 | 08:59 PM
Steve-o's Avatar
my moter seemes to be rougher than before
Old Oct 7, 2005 | 09:07 PM
rougher?? I don't know what that means.
dirt, dust and sand inside my engine is what killed it.
Old Oct 7, 2005 | 09:14 PM
Steve-o's Avatar
sorry mispelled, i was trying to say more vibration! (i've been up for a long time kinda buzzin!!
Old Oct 7, 2005 | 09:35 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve-o &raquo;</TD></TR><TR><TD CLASS="quote">sorry mispelled, i was trying to say more vibration! (i've been up for a long time kinda buzzin!!</TD></TR></TABLE>
last tune up? oil-change?, is your timing ok?, how are your engine mounts looking? ive had the same ls engine for 2 years i got it at 127k miles and its now got 172k miles and all of those miles ive redlined numerous times a day, the only problem that engine had was the person before me burned 2 exhaust valves in cylider 3 and the machine shop he got the work done at used the old valve seals and also hot-tanked the head, so all the seal were toast. the engine smoked(blue)alot at idle and start up. i fixed the seals and no problems since....other than the normal aged engine problems(a knock here and there)
Old Oct 7, 2005 | 09:42 PM
Steve-o's Avatar
Default Re: engine mechanical problems? (projectTeG)
tune up was done before i got the car, there is 110 thousand on it now, the moter doesn't smoke, i use castrol syntec 10w30,,,,the engine just feels like it isn't very smoth!? i don't know maybe i am just crazy!! haha
Old Oct 7, 2005 | 09:43 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve-o &raquo;</TD></TR><TR><TD CLASS="quote">tune up was done before i got the car, there is 110 thousand on it now, the moter doesn't smoke, i use castrol syntec 10w30,,,,the engine just feels like it isn't very smoth!? i don't know maybe i am just crazy!! haha </TD></TR></TABLE>
recent valve adjustment done? not having the valve clearances in spec can cause the engine to be rough.
Old Oct 7, 2005 | 09:46 PM
Steve-o's Avatar
I hade the vales checked about 5,000 miles ago this just started today
Old Oct 7, 2005 | 09:48 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve-o &raquo;</TD></TR><TR><TD CLASS="quote">I hade the vales checked about 5,000 miles ago this just started today</TD></TR></TABLE>
hows your exhaust? and you catalytic converter?
Old Oct 7, 2005 | 09:49 PM
Steve-o's Avatar
i think my cat may be backed up i just put a cat back system on about 2 weeks ago
Old Oct 7, 2005 | 09:52 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve-o &raquo;</TD></TR><TR><TD CLASS="quote">i think my cat may be backed up i just put a cat back system on about 2 weeks ago</TD></TR></TABLE>
yea check your cat out, i had a clogged cat and it made a world of difference once it was off....no more rough idle...no nothing...lol well before you go and replace the cat, try and run seafoam through the engine and see if that helps
Old Oct 8, 2005 | 09:12 PM
Steve-o's Avatar
hey I will try that foam stuff you were talking about! I am going to replace my cat to it is clogged up I think!
Eibach95Civic
13
Dec 20, 2015 09:39 PM
2ndchirp
Apr 18, 2008 10:11 AM
B16b-EJ8
Mar 26, 2008 04:21 PM
austrian type-R
Jan 21, 2005 04:53 PM
GumballNA
Nov 25, 2002 02:28 PM
