thermostat question??
Old Oct 6, 2005 | 06:23 PM
hnp5's Avatar
Default thermostat question??
sup i have a gsr motor...and i never changed a thermostat in my life...im guessing that it is on the lower radiator hose that attaches some where around the manifold?? is it the lower rad hose?? the one i have to follow or the upper? thanx
Old Oct 6, 2005 | 06:26 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: thermostat question?? (cuban0)
Hehe, I saw you post this in the Type R forum.
Anyway, follow the lower radiator hose. It will go into the block (not any sort of manifold like you say). There you will see it goes into something that's round shaped. That piece of the block can be unbolted with two 12mm (or might be 10mm) bolts.
Do a search on "thermostat" in the Integra forum and you'll find several threads on it, along with some pictures.
It's a very easy procedure and should take you 15 minutes, even if you have no auto mechanical knowledge. Note, that you will need to drain at least some of the coolant.
EDIT: These might help:
https://honda-tech.com/zerothread?id=1360304
https://honda-tech.com/zerothread?id=1355563 (Hey, I posted in that )
And woah...here's the best one: http://www.team-integra.net/se...D=222 (with pictures )
Old Oct 6, 2005 | 06:32 PM
hnp5's Avatar
Default Re: thermostat question?? (shamoo)
lol thanx man
Dekorum
May 15, 2014 05:13 PM
soon2bdropped
Aug 15, 2010 06:18 PM
azandford
May 18, 2010 07:46 AM
hnp5
Oct 6, 2005 09:03 PM
leptolude
Oct 9, 2002 07:54 PM
