PS Return Hose Issue??
Old Apr 24, 2022 | 02:26 PM
CaponeK's Avatar
Icon5 PS Return Hose Issue??
So the seal(s) on my rack went out, and while putting in a new rack I decided to take a look at the reservior and the hoses...
And apparently the idiot I bought the car from has zip tied the reservior to the cooling lines because the clip on it is nowhere to be found. Because of this the return hose has been kind of tucked to the right of where the reservoir is and the hose is slightly crimped. I'm assuming this contributed if not completely caused the seals to go out on my rack.
I say all of this to ask; Would using a larger return hose than 3/8s cause me any problems? I think using a bigger hose might still allow the correct amount of fluid back into the reservoir even if it does crimp a little bit. Which at this point I think is inevitable because of the position of the reservoir... Because right now there's literally nothing I can do with the current hose to make it not crimp, and I'd rather like to keep my new rack's seals in tact.
Old Apr 25, 2022 | 06:09 AM
safedriver's Avatar
Default Re: PS Return Hose Issue??
Buy a barely running parts car or is that what you're bring back to life?
Old Apr 25, 2022 | 10:54 AM
CaponeK's Avatar
Honestly don't have the funds for that right now lol. But no this is my DD IM working on hence why I want/need to fix it asap.
*edit*
Also curious about using a reservoir from like an Accord that has the connections on the same side of the reservoir???
rnacion
Mar 24, 2014 08:47 AM
Jared
Nov 30, 2003 04:23 PM
Xerxes
Jan 27, 2002 10:48 PM
